Aller au contenu principal
Canon PowerShot SD1000 Shutter Button Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SD1000 Shutter Button Replacement, Back Panel: étape 1, image 1 de 2 Canon PowerShot SD1000 Shutter Button Replacement, Back Panel: étape 1, image 2 de 2
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 Shutter Button Replacement: étape 2, image 1 de 1
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 Shutter Button Replacement: étape 3, image 1 de 1
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 Shutter Button Replacement: étape 4, image 1 de 1
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 Shutter Button Replacement: étape 5, image 1 de 1
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 Shutter Button Replacement, Front Case: étape 6, image 1 de 1
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 Shutter Button Replacement: étape 7, image 1 de 1
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  8. Canon PowerShot SD1000 Shutter Button Replacement, Shutter Button: étape 8, image 1 de 2 Canon PowerShot SD1000 Shutter Button Replacement, Shutter Button: étape 8, image 2 de 2
    • Using the spudger, take off the shutter button by prying the small tab on the front side of the camera.
Phillip Phung
Membre depuis le 01/19/12
624 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 8-18, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 6
Total : 1,131
