Introduction
The battery for this camera may die when used frequently. This guide explains how to replace the battery.
Outils
Aucun outil requis.
The battery compartment is located on the bottom of the camera, below the user interface panel.
  • The battery compartment is located on the bottom of the camera, below the user interface panel.
Ajouter un commentaire
The hatch covering the memory card will slide open towards the corner of the device.
  • The hatch covering the memory card will slide open towards the corner of the device.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Once the hatch is slid so the end is overhanging the edge of the camera, you will be able to lift it open.
  • Once the hatch is slid so the end is overhanging the edge of the camera, you will be able to lift it open.
Once open, you will see a small orange tab near the corner of the camera.
  • Once open, you will see a small orange tab near the corner of the camera.
  • Push this tab towards the front face of the device, and the battery will freely fall out from the hatch.
Matt Holquist
Membre depuis le 01/02/2018
109 Réputation
1 tutoriel rédigé
Équipe
Baylor, Team S1-G3, Johnson Spring 2018 Membre de l'équipe Baylor, Team S1-G3, Johnson Spring 2018
BU-JOHNSON-S18S1G3
3 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 36
