Introduction
Removing the buttons might be necessary if a button is damaged. This guide will show how to remove all external buttons on the camera.
Ce dont vous avez besoin
Use your fingernail to slide the dark gray tab located on the bottom of the device towards the edge of camera.
Slide the light gray door away from the LCD screen and pull up to open the door.
Close the light gray battery compartment door.
Remove the six 2.8 mm Phillips screws on the outside of the case. Two screws are found on each side of the camera, and the final two are found on the bottom.
