Introduction
Follow this step by step installation guide for replacing the motherboard on your Canon Powershot SD700 IS camera.
In order to make the process easier please view our more indepth guide on taking off the camera's casing in the LCD replacement guide.
Pièces
Aucune pièce nécessaire.
Turn off camera by pressing power button above the LCD screen.
  • Turn off camera by pressing power button above the LCD screen.
  • Remove the battery and memory card.
Ajouter un commentaire
Remove the screws on the bottom of the camera using a 00 Philip's head screw driver
  • Remove the screws on the bottom of the camera using a 00 Philip's head screw driver
Remove the screws on the right side of the camera.
  • Remove the screws on the right side of the camera.
Remove the screws on the left of the camera underneath the "A/V out Digital" cover flap.
  • Remove the screws on the left of the camera underneath the "A/V out Digital" cover flap.
Remove the screws on the bottom of the camera near the battery and the memory card slots.
  • Remove the screws on the bottom of the camera near the battery and the memory card slots.
  • This screw is longer than the rest of the screws.
Remove the front back and side casings from the camera.
  • Remove the front back and side casings from the camera.
Once the LCD and Backlight are detached, remove the larger screw marked in red in the picture as well as the four smaller sized screws marked in blue.
  • Once the LCD and Backlight are detached, remove the larger screw marked in red in the picture as well as the four smaller sized screws marked in blue.
On my camera (SD700) there were no screws where yellow circles are. There was a total of 5 screws in this step which should be easy to spot. It is important however to keep track of which screw goes where as there is 3 different size screws in this step.
Mike - Réponse
Remove the two screws near the the tri-pod mount with a Philips head screw driver.
  • Remove the two screws near the the tri-pod mount with a Philips head screw driver.
One of the 2 screw locations in diagram is wrong. One screw goes through flex circuit but the other screw goes in the hole in top left of picture closest to LCD assembly.
Mike - Réponse
I should clarify - the second screw goes in the hole just above and left of tripod lug hole.
Mike - Réponse
Remove the screw next to the shutter with a Philip's head screw driver.
  • Remove the screw next to the shutter with a Philip's head screw driver.
Remove the orange ribbon cable by lifting the ZIF connector attached to the ribbon with a flat head screw driver or spudger.
  • Remove the orange ribbon cable by lifting the ZIF connector attached to the ribbon with a flat head screw driver or spudger.
Need to remove another screw from lower right corner of main board cover (partially hidden by flex circuit) before cover can be removed.
Mike - Réponse
Carefully lift the shutter along with the ribbon connected to it. This will remove the casing around the motherboard. Carefully lift the shutter along with the ribbon connected to it. This will remove the casing around the motherboard.
  • Carefully lift the shutter along with the ribbon connected to it. This will remove the casing around the motherboard.
With the motherboard casing detached, remove the short orange ribbon by lifting the ZIF connector with a spudger or other plastic opening tools and slide the ribbon out. Detaching this ribbon will disconnect the side of the camera containing the motherboard from the rest of the camera. With the motherboard casing detached, remove the short orange ribbon by lifting the ZIF connector with a spudger or other plastic opening tools and slide the ribbon out. Detaching this ribbon will disconnect the side of the camera containing the motherboard from the rest of the camera. With the motherboard casing detached, remove the short orange ribbon by lifting the ZIF connector with a spudger or other plastic opening tools and slide the ribbon out. Detaching this ribbon will disconnect the side of the camera containing the motherboard from the rest of the camera.
  • With the motherboard casing detached, remove the short orange ribbon by lifting the ZIF connector with a spudger or other plastic opening tools and slide the ribbon out. Detaching this ribbon will disconnect the side of the camera containing the motherboard from the rest of the camera.
First remove the wires that are attached to the motherboard, as shown by the black box. You can detach them by simply pulling them out. Next you can remove the film by lifting it gently from the motherboard.
  • First remove the wires that are attached to the motherboard, as shown by the black box. You can detach them by simply pulling them out.
  • Next you can remove the film by lifting it gently from the motherboard.
Remove the last wires connected to the motherboard. You can remove it by gently lifting it upwards.
  • Remove the last wires connected to the motherboard. You can remove it by gently lifting it upwards.
Place a flathead screwdriver and gently lift the circuit attached, as shown on the picture. Place a flathead screwdriver and gently lift the circuit attached, as shown on the picture.
  • Place a flathead screwdriver and gently lift the circuit attached, as shown on the picture.
Remove the screw using a philip 00 screwdriver. Once the screw is removed, gently lift the motherboard away from the case.
  • Remove the screw using a philip 00 screwdriver.
  • Once the screw is removed, gently lift the motherboard away from the case.
Remove the screw as shown by the red circle. Once the screw is removed, you can remove the board.
  • Remove the screw as shown by the red circle.
  • Once the screw is removed, you can remove the board.
Kenneth Lim
Membre depuis le 07/04/2011
61 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 9-71, Walters Spring 2011 Membre de l'équipe Cal Poly, Team 9-71, Walters Spring 2011
CPSU-WALTERS-S11S9G71
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,151
