Aller au contenu principal
Canon PowerShot SD780 IS Flash Capacitor Replacement
Ce dont vous avez besoin
    • Begin by making sure the camera is turned off and the battery has been removed to avoid any shock injuries.
  1. Canon PowerShot SD780 IS Flash Capacitor Replacement: étape 2, image 1 de 2 Canon PowerShot SD780 IS Flash Capacitor Replacement: étape 2, image 2 de 2
    • Having removed the battery, you can begin removing the outermost screws on the camera to allow for case replacement. There are 5 screws in total. This will require a Philips head # 00 screwdriver.
    • Keep track of where each screw came from in order to avoid complications during the reassemble process.
    • The screws highlighted by the red square in the second image (on the left side in the first image) are 2.0 mm long.
  2. Canon PowerShot SD780 IS Flash Capacitor Replacement: étape 3, image 1 de 1
    • Remove the front panel of the camera case to expose the top left copper strip, and gently pull the strip upward to disconnect from camera.
  3. Canon PowerShot SD780 IS Flash Capacitor Replacement: étape 4, image 1 de 1
    • Remove the screw on the far left hand side of the camera.
  4. Canon PowerShot SD780 IS Flash Capacitor Replacement: étape 5, image 1 de 1
    • Now that you have removed all of the screws, carefully pull the case apart at the seem. The case will detach from the camera in two pieces.
  5. Canon PowerShot SD780 IS Flash Capacitor Replacement: étape 6, image 1 de 1
    • Locate the image stabilizer on the top right of the camera and pry the internal battery away from the camera. Having done this, the internal battery can be removed easily.
  6. Canon PowerShot SD780 IS Flash Capacitor Replacement: étape 7, image 1 de 1
    • You have now exposed the internal battery, and you may proceed to exchange the old internal battery for a new one.
Arlene Ale
Membre depuis le 03/13/14
455 Réputation
4 tutoriels rédigés
Équipe
New Mexico State, Team 1-5, Easley Spring 2014 Membre de l'équipe New Mexico State, Team 1-5, Easley Spring 2014
NMSU-EASLEY-S14S1G5
2 membres
4 tutoriels rédigés
Un commentaire
what is the number for the replacement battery?
peterprosser - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 32
Total : 921
