Aller au contenu principal
Canon PowerShot SD870 IS Shutter Release Button Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SD870 IS Shutter Release Button Replacement, Outer Case: étape 1, image 1 de 1
    • Remove the wrist strap, if present.
    • Remove the lithium-ion battery.
  2. Canon PowerShot SD870 IS Shutter Release Button Replacement: étape 2, image 1 de 3 Canon PowerShot SD870 IS Shutter Release Button Replacement: étape 2, image 2 de 3 Canon PowerShot SD870 IS Shutter Release Button Replacement: étape 2, image 3 de 3
    • Remove the two 4 mm Phillips #00 screws on the bottom of the camera.
    • Remove the screw next to the wrist strap attachment.
    • Pull up the “A/V OUT DIGITAL” cover and remove the screw above the USB port.
  3. Canon PowerShot SD870 IS Shutter Release Button Replacement: étape 3, image 1 de 1
    • Carefully unhook the “A/V OUT DIGITAL” cover from the hinge.
  4. Canon PowerShot SD870 IS Shutter Release Button Replacement: étape 4, image 1 de 2 Canon PowerShot SD870 IS Shutter Release Button Replacement: étape 4, image 2 de 2
    • Pull the front cover from the camera by using gentle upward pressure.
  5. Canon PowerShot SD870 IS Shutter Release Button Replacement: étape 5, image 1 de 2 Canon PowerShot SD870 IS Shutter Release Button Replacement: étape 5, image 2 de 2
    • Remove the two Phillips #00 screws from the flat end of the camera.
    • Remove the black L-shaped side cover plate.
    • Remove the silver u-shaped retainer plate.
  6. Canon PowerShot SD870 IS Shutter Release Button Replacement: étape 6, image 1 de 1
    • Slide the back casing off.
  7. Canon PowerShot SD870 IS Shutter Release Button Replacement, LCD: étape 7, image 1 de 1
    • The first screw that needs to be removed is located on the bottom of the camera, on the left hand side.
    • Using a Phillips #00 screwdriver remove the 0.133in silver screw on the bottom left-hand side.
  8. Canon PowerShot SD870 IS Shutter Release Button Replacement: étape 8, image 1 de 2 Canon PowerShot SD870 IS Shutter Release Button Replacement: étape 8, image 2 de 2
    • The second screw that needs to be removed is located on the top of the camera.
    • Using the same Phillips head screwdriver, remove the last 0.133in silver screw.
    • This will detach a silver U-shaped piece that was holding LCD screen on. Remove the piece and put it to the side.
  9. Canon PowerShot SD870 IS Shutter Release Button Replacement: étape 9, image 1 de 1
    • The LCD screen should now only be attached by the LCD data cable.
    • Lift the screen from the right side and use a small screwdriver or other small opening device to flip the black portion of the connector upward to unlock it.
    • Carefully slide the data cable out of the connector.
    • The LCD should still be connected by the backlight cable.
  10. Canon PowerShot SD870 IS Shutter Release Button Replacement: étape 10, image 1 de 2 Canon PowerShot SD870 IS Shutter Release Button Replacement: étape 10, image 2 de 2
    • To remove the backlight cable, use another small opening device to unlock the backlight cable.
    • Carefully slide out the backlight cable.
    • The LCD screen should now be fully detached from the camera body.
  11. Canon PowerShot SD870 IS Shutter Release Button Replacement: étape 11, image 1 de 1
    • The LCD screen casing is connected by 4 claws located on the top and bottom on the left and right hand side.
    • Carefully disengage the claws by gently prying them off one by one.
    • Once the claws are disengaged, the back of the casing will still be connected to the front casing by the backlight cable.
    • Carefully peel the backlight cable off of the casing.
  12. Canon PowerShot SD870 IS Shutter Release Button Replacement: étape 12, image 1 de 1
    • The LCD screen and housing should now be in three pieces:
    • LCD screen
    • LCD screen frame
    • LCD screen back housing
    • The LCD screen itself can now be removed and fixed/replaced.
  13. Canon PowerShot SD870 IS Shutter Release Button Replacement, Shutter Release Button: étape 13, image 1 de 2 Canon PowerShot SD870 IS Shutter Release Button Replacement, Shutter Release Button: étape 13, image 2 de 2
    • With the case and LCD screen removed, you are ready to remove the release button.
    • Begin by using the Philips #00 screwdriver to remove two silver 0.159in screws on the top and front of the camera.
  14. Canon PowerShot SD870 IS Shutter Release Button Replacement: étape 14, image 1 de 1
    • The top plastic piece holding the release button should be held on only by a red-and-black wire connector to the logic board.
    • Remove the connector from the logic board and detach the release button housing from the camera.
  15. Canon PowerShot SD870 IS Shutter Release Button Replacement: étape 15, image 1 de 2 Canon PowerShot SD870 IS Shutter Release Button Replacement: étape 15, image 2 de 2
    • With the plastic housing for the release button removed from the camera, use the Philips #00 screwdriver to remove two silver 0.090in screws.
    • The release button can now be removed and fixed or replaced.
Sam
Membre depuis le 04/15/10
155 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 10-45, Garner Spring 2010 Membre de l'équipe Cal Poly, Team 10-45, Garner Spring 2010
CPSU-GARNER-S10S10G45
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 3,447
