Introduction
First remove the back casing and control dial before attempting to remove buttons.
Ce dont vous avez besoin
Turning the camera so the screen is facing you.
Remove the two black 3.4 mm screws with a Phillips #00 screwdriver.
Turn the camera with the lens facing down.
Use the iFixit opening tool to make leverage. Insert the opening tool in the seam where the front case and the back case assemble.
Carefully put pressure on the opening tool so the cover can gradually open.
Slowly slide the opening tool along the gap and around the edge of the camera.
Carefully remove the pin underneath the dial using a pair of tweezers and set it aside.
Use a pair of tweezers to remove the old control dial and set the new control in the same place.
Once casing and control dial have been removed, you will begin removing silicone button pad.
Use tweezers to grip the edge of the silicone pad and begin lifting upward.
