Introduction
The flash unit provides necessary lighting when not enough is available.
Pièces
Aucune pièce nécessaire.
Slide grey latch to open the battery compartment. Slide grey latch to open the battery compartment.
  • Slide grey latch to open the battery compartment.
Ajouter un commentaire
Push orange retaining clip to the right to free battery. Push orange retaining clip to the right to free battery.
  • Push orange retaining clip to the right to free battery.
Remove battery from the camera.
  • Remove battery from the camera.
Remove the lanyard.
  • Remove the lanyard.
Remove the two 2.3mm screws (underneath the name plate) and two 2.8mm screws (next to the threaded tripod mount) from the bottom face of the camera.
  • Remove the two 2.3mm screws (underneath the name plate) and two 2.8mm screws (next to the threaded tripod mount) from the bottom face of the camera.
  • Be careful to keep track of the different screw sizes as you proceed with this guide.
Remove the single 3.8mm screw from the back face of the camera.
  • Remove the single 3.8mm screw from the back face of the camera.
Remove the two 2.3mm screws from the right face of the camera.
  • Remove the two 2.3mm screws from the right face of the camera.
Remove the two 3.2mm screws (outside edge) and two 3.7mm screws (towards middle) from the left side of the camera body.
  • Remove the two 3.2mm screws (outside edge) and two 3.7mm screws (towards middle) from the left side of the camera body.
Pull the back face panel away from the front end of the body. This may take some wiggling and force.
  • Pull the back face panel away from the front end of the body. This may take some wiggling and force.
Remove the CF card door from the left side of the camera body. Remove the CF card door from the left side of the camera body.
  • Remove the CF card door from the left side of the camera body.
Remove the rubber digital a/v out cap by sliding it out of the groove on the front plate. Remove the rubber digital a/v out cap by sliding it out of the groove on the front plate.
  • Remove the rubber digital a/v out cap by sliding it out of the groove on the front plate.
Remove the front face by sliding it off.
  • Remove the front face by sliding it off.
Remove the rubber seal that goes over the right side of the viewfinder.
  • Remove the rubber seal that goes over the right side of the viewfinder.
Remove the two 3.9mm screws that retain the laminated cooper sheet.
  • Remove the two 3.9mm screws that retain the laminated cooper sheet.
Remove the seven wire connections that connect to the motherboard. Remove the seven wire connections that connect to the motherboard.
  • Remove the seven wire connections that connect to the motherboard.
Remove the single 3.8mm screw that is on the motherboard.
  • Remove the single 3.8mm screw that is on the motherboard.
Carefully remove the motherboard from the main frame of the camera body.
  • Carefully remove the motherboard from the main frame of the camera body.
After completing the removal of the motherboard, remove the tripod mounting screws (3.4mm) on the left side
  • After completing the removal of the motherboard, remove the tripod mounting screws (3.4mm) on the left side
Carefully pry the left side of the housing plate from the bottom of the tripod mounting plate, releasing it from the two alignment pegs next to the screws
  • Carefully pry the left side of the housing plate from the bottom of the tripod mounting plate, releasing it from the two alignment pegs next to the screws
Lift the left side of the tripod mounting plate towards you, lift free the mounting plate from the rest of the assembly
  • Lift the left side of the tripod mounting plate towards you, lift free the mounting plate from the rest of the assembly
  • Be careful because there are still wire connections attached to the mounting plate which you don't want to remove
Remove the 2.1mm screws from the bottom and top of the screen connecting it to the housing plate
  • Remove the 2.1mm screws from the bottom and top of the screen connecting it to the housing plate
Unsolder the four points at the top of the screen with a soldering iron
  • Unsolder the four points at the top of the screen with a soldering iron
  • You do not need to unsolder the screen to get to the lens, but follow the rest of the steps to free the screen from the housing plate.
Remove the card-reader shield by removing the screw at the top of the shield.
  • Remove the card-reader shield by removing the screw at the top of the shield.
Remove the 2 black screws that attach the battery box to the housing plate. The second picture shows the battery box detached from the housing plate.
  • Remove the 2 black screws that attach the battery box to the housing plate.
  • The second picture shows the battery box detached from the housing plate.
Remove the three (3.1mm) black screws that were behind the screen and battery box.
  • Remove the three (3.1mm) black screws that were behind the screen and battery box.
Carefully remove the lens. Remove the bottom side of the lens first before the viewfinder side.
  • Carefully remove the lens.
  • Remove the bottom side of the lens first before the viewfinder side.
  • Be careful of wires and delicate parts.
Remove the 3.3 mm screw from underneath the clear plastic flash unit on the front side.
  • Remove the 3.3 mm screw from underneath the clear plastic flash unit on the front side.
Remove the 3.4mm screw from the top of the flash unit and housing plate.
  • Remove the 3.4mm screw from the top of the flash unit and housing plate.
Remove the 2.1mm screw from the interlocking clip on the right. Remove the 2.1mm screw from the interlocking clip on the right.
  • Remove the 2.1mm screw from the interlocking clip on the right.
Pull the flash unit away from the interlocking clip on the housing plate. This will require some maneuvering to free the interlocking clip from the housing plate.
  • Pull the flash unit away from the interlocking clip on the housing plate.
  • This will require some maneuvering to free the interlocking clip from the housing plate.
Slide the flash unit to the left and away from the housing plate. Slide the flash unit to the left and away from the housing plate.
  • Slide the flash unit to the left and away from the housing plate.
Unsolder the pink wire from the condenser.
  • Unsolder the pink wire from the condenser.
Remove the clear plastic cover from the white wire by lifting off with finger. Desolder the white wire.
  • Remove the clear plastic cover from the white wire by lifting off with finger.
  • Desolder the white wire.
Remove the gray wire by  desoldering it from the underside of the flash unit.
  • Remove the gray wire by desoldering it from the underside of the flash unit.
Carefully pull the flash unit off the condenser. There is tape underneath, so some force may be required.
  • Carefully pull the flash unit off the condenser. There is tape underneath, so some force may be required.
Tanya
Membre depuis le 20/04/2011
111 Réputation
1 tutoriel rédigé
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 611
