Aller au contenu principal
Canon Powershot S200 Motherboard Replacement
Ce dont vous avez besoin
  1. Canon Powershot S200 Motherboard Replacement, Battery: étape 1, image 1 de 2 Canon Powershot S200 Motherboard Replacement, Battery: étape 1, image 2 de 2
    • Slide the grey latch to open the battery compartment.
  2. Canon Powershot S200 Motherboard Replacement: étape 2, image 1 de 2 Canon Powershot S200 Motherboard Replacement: étape 2, image 2 de 2
    • Push and slide the orange retaining clip to the right to remove the battery.
  3. Canon Powershot S200 Motherboard Replacement: étape 3, image 1 de 1
    • Remove battery from the camera.
  4. Canon Powershot S200 Motherboard Replacement, Motherboard: étape 4, image 1 de 1
    • Remove the lanyard.
  5. Canon Powershot S200 Motherboard Replacement: étape 5, image 1 de 1
    • Position the camera so that the bottom is facing up.
    • Remove the two 2.3mm screws beneath the name plate.
    • Remove the two 2.8 mm screws surrounding the threaded tripod mount.
  6. Canon Powershot S200 Motherboard Replacement: étape 6, image 1 de 1
    • Remove the 3.8mm screw from the back face of the camera.
  7. Canon Powershot S200 Motherboard Replacement: étape 7, image 1 de 1
    • Remove the two 2.3mm screws from the right face of the camera.
  8. Canon Powershot S200 Motherboard Replacement: étape 8, image 1 de 1
    • Remove the two outer 3.2mm screws from the left side of the camera
    • Remove the two inner 3.7mm screws from the left side of the camera.
  9. Canon Powershot S200 Motherboard Replacement: étape 9, image 1 de 1
    • Pull the back face panel away from the front end of the body. This may take some wiggling and force.
  10. Canon Powershot S200 Motherboard Replacement: étape 10, image 1 de 2 Canon Powershot S200 Motherboard Replacement: étape 10, image 2 de 2
    • Remove the CF card door from the left side of the camera body.
  11. Canon Powershot S200 Motherboard Replacement: étape 11, image 1 de 2 Canon Powershot S200 Motherboard Replacement: étape 11, image 2 de 2
    • Slide the rubber digital a/v cap out of place on the front plate.
  12. Canon Powershot S200 Motherboard Replacement: étape 12, image 1 de 1
    • Remove the front face by sliding it off.
  13. Canon Powershot S200 Motherboard Replacement: étape 13, image 1 de 1
    • Remove the rubber seal that covers the right side of the viewfinder.
  14. Canon Powershot S200 Motherboard Replacement: étape 14, image 1 de 1
    • Remove the two 3.9mm screws that hold the laminated copper sheet.
  15. Canon Powershot S200 Motherboard Replacement: étape 15, image 1 de 2 Canon Powershot S200 Motherboard Replacement: étape 15, image 2 de 2
    • Remove the wire connections that connect along the bottom of the motherboard.
  16. Canon Powershot S200 Motherboard Replacement: étape 16, image 1 de 1
    • Remove the single 3.8mm screw that is on the motherboard.
  17. Canon Powershot S200 Motherboard Replacement: étape 17, image 1 de 1
    • Remove the motherboard from the main frame of the camera body.
Orlando Zuniga
Membre depuis le 04/14/11
11 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 20-70, Walters Spring 2011 Membre de l'équipe Cal Poly, Team 20-70, Walters Spring 2011
CPSU-WALTERS-S11S20G70
5 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 1,879
