Introduction
Take off outer cover, detach cable, and remove Release Button.
Squeeze the sides of the plastic connector while gently detaching the cable. Your shutter release button is now removed and can be replaced. The shutter release button assembly should only be attached by a small red and black wire, with a plastic connector at the end.
  • Squeeze the sides of the plastic connector while gently detaching the cable. Your shutter release button is now removed and can be replaced.
    • The shutter release button assembly should only be attached by a small red and black wire, with a plastic connector at the end.
Ajouter un commentaire
Stanley
Membre depuis le 30/01/2011
369 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 4-33, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 4-33, Regan Winter 2011
CPSU-REGAN-W11S4G33
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 893
