Pièces
Aucune pièce nécessaire.
Remove the 2 screws(2.41mm long) on the side of the camera next to the LCD screen. Remove the 2 screws(4.08mm) on the other side.  One is located under the rubber USB flap. Remove the last screw(2.59mm) located on the bottom of the camera.
  • Remove the 2 screws(2.41mm long) on the side of the camera next to the LCD screen.
  • Remove the 2 screws(4.08mm) on the other side. One is located under the rubber USB flap.
  • Remove the last screw(2.59mm) located on the bottom of the camera.
  • Slowly pull the back cover of the camera.
Ajouter un commentaire
Remove the screw(2.59mm) from the bottom of the camera. Remove the screw(4.08mm) from the menu button side of the camera. The 2 screws on the other side of the camera were already removed when taking off the back cover.
  • Remove the screw(2.59mm) from the bottom of the camera.
  • Remove the screw(4.08mm) from the menu button side of the camera.
  • The 2 screws on the other side of the camera were already removed when taking off the back cover.
Robert Manno
Membre depuis le 05/01/2011
432 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 13-3, Forte Winter 2011 Membre de l'équipe Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 2,584
