Aller au contenu principal
Canon Powershot SD880 Top Panel Replacement
Ce dont vous avez besoin
  1. Canon Powershot SD880 Top Panel Replacement, Back Cover: étape 1, image 1 de 3 Canon Powershot SD880 Top Panel Replacement, Back Cover: étape 1, image 2 de 3 Canon Powershot SD880 Top Panel Replacement, Back Cover: étape 1, image 3 de 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 Top Panel Replacement, Top Panel: étape 2, image 1 de 2 Canon Powershot SD880 Top Panel Replacement, Top Panel: étape 2, image 2 de 2
    • Unplug the green and white plugs that connect the top panel to the top of the logic board.
    • Dislodge the tab above the lens.
    • Dislodge the tab at the back.
Robert Manno
Membre depuis le 01/05/11
432 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 13-3, Forte Winter 2011 Membre de l'équipe Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,023
