Aller au contenu principal
Carburetor Disassembly
Ce dont vous avez besoin
  1. Carburetor Disassembly, Remove air filter + housing: étape 1, image 1 de 3 Carburetor Disassembly, Remove air filter + housing: étape 1, image 2 de 3 Carburetor Disassembly, Remove air filter + housing: étape 1, image 3 de 3
    • Use a 5/16 socket or flat head screwdriver to remove the first bolt. Pull the cover off and remove the air filter.
    • Remove the 3 bolts using a 5/16 socket. In addition, pull the breather hose off the assembly at the bottom left. Now pull the cover off.
  2. Carburetor Disassembly, Remove carburetor: étape 2, image 1 de 3 Carburetor Disassembly, Remove carburetor: étape 2, image 2 de 3 Carburetor Disassembly, Remove carburetor: étape 2, image 3 de 3
    • Remove the two bolts holding the carburetor to the engine with a 3/8 socket or wrench.
    • Remove the spring boxed in red from the hole. Pull to left of carburetor, towards the link the other end of the spring is around.
    • The link will be connected to the carburetor. Pull the carburetor off in an "S" motion and remove it.
Jacob Micallef
Membre depuis le 03/06/17
993 Réputation
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 38
Total : 1,143
