Aller au contenu principal
Casdon Dyson Ball Disassembly
Ce dont vous avez besoin
  1. Casdon Dyson Ball Disassembly, Battery: étape 1, image 1 de 1
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball Disassembly: étape 2, image 1 de 1
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball Disassembly, Casdon Dyson Ball Disassembly: étape 3, image 1 de 1
    • Remove all seven 9.2mm (0.32 in) screws on the back of the vacuum.
  4. Casdon Dyson Ball Disassembly: étape 4, image 1 de 1
    • Remove the front side covers by pulling them away from the vacuum.
  5. Casdon Dyson Ball Disassembly: étape 5, image 1 de 1
    • Separate the battery compartment from the ball and bead cylinder by sliding the vacuum ball away from the battery compartment.
  6. Casdon Dyson Ball Disassembly: étape 6, image 1 de 1
    • Separate the bead cylinder and the fan compartment by pulling the bead cylinder away from the fan compartment.
  7. Casdon Dyson Ball Disassembly: étape 7, image 1 de 1
    • Remove beads from the container.
2 autres ont terminé cette réparation.
Seldon Price
Membre depuis le 11/07/17
612 Réputation
5 tutoriels rédigés
Équipe
IUPUI, Team S3-G5, Harley Fall 2017 Membre de l'équipe IUPUI, Team S3-G5, Harley Fall 2017
IUPUI-HARLEY-F17S3G5
3 membres
10 tutoriels rédigés
2 commentaires
How do I get the handle out once assembled?
Carie McClendon - Réponse
The fan to make the beads jump around no longer works….is there. Separate battery for that?
Kathy - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 33
30 derniers jours : 148
Total : 12,087
