Pièces
Aucune pièce nécessaire.
Flip the keyboard upside down so the bottom is angled towards you.
  • Flip the keyboard upside down so the bottom is angled towards you.
Ajouter un commentaire
Use a #2 Phillips screwdriver to remove the twenty-seven 12 mm screws from the dark gray bottom panel.
  • Use a #2 Phillips screwdriver to remove the twenty-seven 12 mm screws from the dark gray bottom panel.
Remove the bottom panel by lifting the bottom panel up and outward from yourself.
  • Remove the bottom panel by lifting the bottom panel up and outward from yourself.
Flip the entire keyboard so the keys face up, and be careful not to let the bottom drop. Flip the top half of the keyboard and set onto the bottom half with the internal parts facing up.
  • Flip the entire keyboard so the keys face up, and be careful not to let the bottom drop.
  • Flip the top half of the keyboard and set onto the bottom half with the internal parts facing up.
Completely unscrew and remove all six of the screws on the central circuit board.
  • Completely unscrew and remove all six of the screws on the central circuit board.
Lift the circuit board out of your way.
  • Lift the circuit board out of your way.
Remove tape from the LCD screen and remove the screen completely.
  • Remove tape from the LCD screen and remove the screen completely.
Replace the LCD screen and tape it down to the top cover. Replace the LCD screen and tape it down to the top cover.
  • Replace the LCD screen and tape it down to the top cover.
Place the circuit board back on top of the LCD screen and screw all of the screws completely in their original positions.
  • Place the circuit board back on top of the LCD screen and screw all of the screws completely in their original positions.
Jimmy Winne
Membre depuis le 04/10/2012
422 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 9-16, Amido Fall 2012 Membre de l'équipe Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 membres
6 tutoriels rédigés
Where did you get the replacement LCD screen? I'm looking for one for my CTK-573 keyboard mbuseck1@yahoo.com
mbuseck1 - Réponse
Voir les statistiques:
Dernières 24 heures : 4
7 derniers jours : 10
30 derniers jours : 37
Total : 2,572
