Aller au contenu principal
Casio Cassiopeia E-125 Key Pad Replacement
Ce dont vous avez besoin
  1. Casio Cassiopeia E-125 Key Pad Replacement, Battery: étape 1, image 1 de 1
    • Flip the device over to the back side.
  2. Casio Cassiopeia E-125 Key Pad Replacement: étape 2, image 1 de 1
    • Slide the small switch on the back to "MAIN".
  3. Casio Cassiopeia E-125 Key Pad Replacement: étape 3, image 1 de 1
    • Slide the battery cover downwards.
    • Pull off the battery cover.
  4. Casio Cassiopeia E-125 Key Pad Replacement: étape 4, image 1 de 1
    • Pull the black tab to remove the battery.
  5. Casio Cassiopeia E-125 Key Pad Replacement, Touch Screen: étape 5, image 1 de 1
    • Use the Phillips #00 screwdriver to remove the two screws near the top of the device.
  6. Casio Cassiopeia E-125 Key Pad Replacement: étape 6, image 1 de 1
    • Use the Phillips #00 screwdriver to remove the two screws located inside the battery compartment.
  7. Casio Cassiopeia E-125 Key Pad Replacement: étape 7, image 1 de 1
    • Use a spudger or opening tool to separate the two halves of the case.
  8. Casio Cassiopeia E-125 Key Pad Replacement: étape 8, image 1 de 1
    • Pry the two halves of the case apart with the opening tool.
  9. Casio Cassiopeia E-125 Key Pad Replacement: étape 9, image 1 de 1
    • Potential for device damage. Do not pull apart the wires connecting the outer case.
    • Lay the two halves of the outer case next to the central components as shown.
  10. Casio Cassiopeia E-125 Key Pad Replacement: étape 10, image 1 de 1
    • Use the Philips #00 screwdriver to remove the three screws in the corners of the screen.
  11. Casio Cassiopeia E-125 Key Pad Replacement: étape 11, image 1 de 2 Casio Cassiopeia E-125 Key Pad Replacement: étape 11, image 2 de 2
    • Lift the tab on the motherboard and pull out the ribbon cable.
    • After the ribbon cable is detached from the motherboard, the touch screen is completely separated from the device.
  12. Casio Cassiopeia E-125 Key Pad Replacement, Key Pad: étape 12, image 1 de 1
    • Use the Phillips #00 screwdriver and remove the five screws from the daughterboard.
  13. Casio Cassiopeia E-125 Key Pad Replacement: étape 13, image 1 de 1
    • Pull the ribbon cable out of its port on the back of the keypad.
  14. Casio Cassiopeia E-125 Key Pad Replacement: étape 14, image 1 de 1
    • Now, lift the keypad off the front case.
Ryan Fernandez
Membre depuis le 04/03/12
47 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 5-4, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 5-4, Forte Spring 2012
CPSU-FORTE-S12S5G4
6 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 5
Total : 615
