Introduction
This guide shows how to remove the LCD screen from the camera. You may have to replace a broken or shattered screen.
Pièces
Aucune pièce nécessaire.
Locate 12 screws. Four on the left, four on the right, and four on the bottom. Locate 12 screws. Four on the left, four on the right, and four on the bottom. Locate 12 screws. Four on the left, four on the right, and four on the bottom.
  • Locate 12 screws. Four on the left, four on the right, and four on the bottom.
Ajouter un commentaire
Using the #00 Phillips screwdriver, remove the four 3.66mm screws from the bottom outer case, and the eight 1.75mm screw from the sides of the case.
  • Using the #00 Phillips screwdriver, remove the four 3.66mm screws from the bottom outer case, and the eight 1.75mm screw from the sides of the case.
Separate the front case from the body of the camera.
  • Separate the front case from the body of the camera.
Separate the back case from the body of the camera.
  • Separate the back case from the body of the camera.
Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up. Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up. Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up.
  • Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up.
Before removing the side metal bracket, first remove the attached strap knob by twisting it off.
  • Before removing the side metal bracket, first remove the attached strap knob by twisting it off.
  • Then, remove the side metal bracket by inserting the plastic opening tool under the bracket and pulling up.
Using the plastic opening tool, pry up the LCD screen starting at one of the corners. Insert the tool under one of the corners and lift up.
  • Using the plastic opening tool, pry up the LCD screen starting at one of the corners. Insert the tool under one of the corners and lift up.
Continue to lift the LCD screen all the way up. Be careful not to rip any wires connecting the LCD screen to the top of the camera.
  • Continue to lift the LCD screen all the way up.
  • Be careful not to rip any wires connecting the LCD screen to the top of the camera.
Laura
Membre depuis le 19/04/2012
31 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 9-45, Regan Spring 2012 Membre de l'équipe Cal Poly, Team 9-45, Regan Spring 2012
CPSU-REGAN-S12S9G45
7 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 11
Total : 1,066
