Introduction
If you have experienced a decrease in the quality of sound, you may want to replace the speaker. This guide exposes the speaker for either investigation or replacement.
Remove the strap from the camera by pulling the thin cord out, creating a small loop, then pushing the thicker cord back through this loop. Remove the strap from the camera by pulling the thin cord out, creating a small loop, then pushing the thicker cord back through this loop. Remove the strap from the camera by pulling the thin cord out, creating a small loop, then pushing the thicker cord back through this loop.
  • Remove the strap from the camera by pulling the thin cord out, creating a small loop, then pushing the thicker cord back through this loop.
Ajouter un commentaire
Remove the two phillips screws (2.83 mm) from the left side panel of the camera casing. The left panel can now be removed. However, one piece of tape attaches it to the camera, so a spudger may be required to ease the panels off. Repeat for the right side panel of the camera.
  • Remove the two phillips screws (2.83 mm) from the left side panel of the camera casing.
  • The left panel can now be removed. However, one piece of tape attaches it to the camera, so a spudger may be required to ease the panels off.
  • Repeat for the right side panel of the camera.
  • Keep track of which screws go where. There are a couple sets of screws to take out and they are all small and look the same.
Remove the 6 phillips screws (3.69 mm) from the bottom of the camera casing. Remove the 6 phillips screws (3.69 mm) from the bottom of the camera casing. Remove the 6 phillips screws (3.69 mm) from the bottom of the camera casing.
  • Remove the 6 phillips screws (3.69 mm) from the bottom of the camera casing.
Remove the 2 phillips screws (2.79 mm) on the left side of the camera where the metal panel used to be. Repeat for the 2 phillips screws (2.79 mm) right side of the camera. Repeat for the 2 phillips screws (2.79 mm) right side of the camera.
  • Remove the 2 phillips screws (2.79 mm) on the left side of the camera where the metal panel used to be.
  • Repeat for the 2 phillips screws (2.79 mm) right side of the camera.
With the LCD screen facing up towards you, start at the bottom of the camera and gently pull off the back of the casing. With the LCD screen facing up towards you, start at the bottom of the camera and gently pull off the back of the casing.
  • With the LCD screen facing up towards you, start at the bottom of the camera and gently pull off the back of the casing.
With the front side (with the lens) facing up towards you, start at the bottom of the camera and gently pull off the front of the casing. The nob that previously held the camera strap will no longer be attached to the camera once you remove the camera casing. When putting the camera back together, remember to put the nob back into position before replacing the casing. The nob that previously held the camera strap will no longer be attached to the camera once you remove the camera casing. When putting the camera back together, remember to put the nob back into position before replacing the casing.
  • With the front side (with the lens) facing up towards you, start at the bottom of the camera and gently pull off the front of the casing.
  • The nob that previously held the camera strap will no longer be attached to the camera once you remove the camera casing. When putting the camera back together, remember to put the nob back into position before replacing the casing.
Slide the labeled piece toward the LCD screen and release. The tab will spring open.
  • Slide the labeled piece toward the LCD screen and release.
  • The tab will spring open.
Look at the bottom of the camera. Take out the phillips screw (1.77 mm) holding on the bottom plastic piece. The bottom plastic piece is held on to the main frame of the camera only by two thin wires.
  • Look at the bottom of the camera. Take out the phillips screw (1.77 mm) holding on the bottom plastic piece.
  • The bottom plastic piece is held on to the main frame of the camera only by two thin wires.
The speaker is attached to the bottom of the camera casing with tape. Use a spudger to gently peel the speaker away from the camera casing.
  • The speaker is attached to the bottom of the camera casing with tape.
  • Use a spudger to gently peel the speaker away from the camera casing.
Using a soldering station and a solder wick or other solder removal tool, carefully remove the solder holding the two wires of the speaker to the circuit board. There are two other soldering joints right next to the soldering joints for the speaker. These soldering joints are for the LCD screen only and should not be removed. Remove only the solder holding the speaker to the circuit board. There are two other soldering joints right next to the soldering joints for the speaker. These soldering joints are for the LCD screen only and should not be removed. Remove only the solder holding the speaker to the circuit board.
  • Using a soldering station and a solder wick or other solder removal tool, carefully remove the solder holding the two wires of the speaker to the circuit board.
  • There are two other soldering joints right next to the soldering joints for the speaker. These soldering joints are for the LCD screen only and should not be removed. Remove only the solder holding the speaker to the circuit board.
Paul Fallon
Membre depuis le 10/04/2012
114 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 17-28, Amido Spring 2012 Membre de l'équipe Cal Poly, Team 17-28, Amido Spring 2012
CPSU-AMIDO-S12S17G28
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 329
