Pièces
This is the calculator in question.
  • This is the calculator in question.
    • Features a black and white dot matrix screen.
Ajouter un commentaire
Turn the calculator over. Locate the six screws on the rear of the device.
  • Turn the calculator over.
  • Locate the six screws on the rear of the device.
    • These are Philips #00 screws.
  • Keep the screws you remove in a safe place so they don't get lost.
Once the screws are removed, carefully lift the back panel off, lifting the top end first. Place the panel to one side.
  • Once the screws are removed, carefully lift the back panel off, lifting the top end first.
  • Place the panel to one side.
  • You can now see the battery.
Remove the battery
  • Remove the battery
  • Lift it up from the right hand side to avoid damaging the spring.
  • You may find this easier to do by prying it out with the screwdriver.
Now you can insert the new battery Ensure you place it in spring-first.
  • Now you can insert the new battery
    • Ensure you place it in spring-first.
  • Congratulations! You have replaced the battery.
  • When reassembling, take care not to trap the red or black wires in the screws as this would sever them, making the calculator unusable.
  • Once reassembled, the calculator will be turned on. Turn it off to save battery by pressing Shift --> AC.
To reassemble your device, follow these instructions in reverse order, noting the two reassembly instructions in the last step.
22 autre(s) ont terminé cette réparation.
Sam
Membre depuis le 23/09/2012
842 Réputation
1 tutoriel rédigé
For some reason the two top screws made the calculator unstable, but removing them made it stable. Only occurred after removing the battery
Mida Galbraith - Réponse
Voir les statistiques:
Dernières 24 heures : 16
7 derniers jours : 196
30 derniers jours : 750
Total : 27,567
