Aller au contenu principal
Ceiva LF2003 Internal Plastic Screen Frame Replacement
Ce dont vous avez besoin
  1. Ceiva LF2003 Internal Plastic Screen Frame Replacement, Exterior Frame and Matting: étape 1, image 1 de 1
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Ceiva LF2003 Internal Plastic Screen Frame Replacement: étape 2, image 1 de 1
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. Ceiva LF2003 Internal Plastic Screen Frame Replacement: étape 3, image 1 de 1
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  4. Ceiva LF2003 Internal Plastic Screen Frame Replacement: étape 4, image 1 de 1
    • Remove the frame and matte from the device.
  5. Ceiva LF2003 Internal Plastic Screen Frame Replacement, Internal Plastic Screen Frame: étape 5, image 1 de 1
    • Remove the four 7mm Torx T6 screws.
  6. Ceiva LF2003 Internal Plastic Screen Frame Replacement: étape 6, image 1 de 2 Ceiva LF2003 Internal Plastic Screen Frame Replacement: étape 6, image 2 de 2
    • Using the plastic opening tool or your fingers, lift up the frame from any edge.
    • Remove the frame from the device.
Casey Glasgow
Membre depuis le 01/26/14
510 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 9-25, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 9-25, Maness Winter 2014
CPSU-MANESS-W14S9G25
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 86
