Aller au contenu principal
Ceiva LF2003 Power Supply Board Replacement
Ce dont vous avez besoin
  1. Ceiva LF2003 Power Supply Board Replacement, Exterior Frame and Matting: étape 1, image 1 de 1
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Ceiva LF2003 Power Supply Board Replacement: étape 2, image 1 de 1
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. Ceiva LF2003 Power Supply Board Replacement: étape 3, image 1 de 1
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  4. Ceiva LF2003 Power Supply Board Replacement: étape 4, image 1 de 1
    • Remove the frame and matte from the device.
  5. Ceiva LF2003 Power Supply Board Replacement, Internal Plastic Screen Frame: étape 5, image 1 de 1
    • Remove the four 7mm Torx T6 screws.
  6. Ceiva LF2003 Power Supply Board Replacement: étape 6, image 1 de 2 Ceiva LF2003 Power Supply Board Replacement: étape 6, image 2 de 2
    • Using the plastic opening tool or your fingers, lift up the frame from any edge.
    • Remove the frame from the device.
  7. Ceiva LF2003 Power Supply Board Replacement, Display: étape 7, image 1 de 3 Ceiva LF2003 Power Supply Board Replacement, Display: étape 7, image 2 de 3 Ceiva LF2003 Power Supply Board Replacement, Display: étape 7, image 3 de 3
    • Unplug the cable connecting the display to the power supply using the flat end of the spudger to pry the connector away from the circuit board.
    • Alternate applying pressure to the left and right side of the connector to ensure that it does not break.
  8. Ceiva LF2003 Power Supply Board Replacement: étape 8, image 1 de 1
  9. Ceiva LF2003 Power Supply Board Replacement: étape 9, image 1 de 2 Ceiva LF2003 Power Supply Board Replacement: étape 9, image 2 de 2
    • Lift up the display from the left edge and flip display over.
    • Do not lift the display too quickly, as the display is still connected to the main circuit board on the right.
  10. Ceiva LF2003 Power Supply Board Replacement: étape 10, image 1 de 3 Ceiva LF2003 Power Supply Board Replacement: étape 10, image 2 de 3 Ceiva LF2003 Power Supply Board Replacement: étape 10, image 3 de 3
    • Use the spudger to disconnect the ribbon cable from the display by the black pins away from the connector. There is a pin on either side of the connector.
    • Once both pins are released, the ribbon cable should slide easily out.
    • It may be easier if someone else holds the display so the cable does not get ripped out.
  11. Ceiva LF2003 Power Supply Board Replacement: étape 11, image 1 de 1
    • Remove the display assembly from the device.
  12. Ceiva LF2003 Power Supply Board Replacement, Power Supply Board: étape 12, image 1 de 1
  13. Ceiva LF2003 Power Supply Board Replacement: étape 13, image 1 de 2 Ceiva LF2003 Power Supply Board Replacement: étape 13, image 2 de 2
    • Desolder the 3 wires attached to the board.
    • Remove the power supply board from the device.
    • The wires shown were not actually desoldered, but the board will now be separated from the rest of the device.
Casey Glasgow
Membre depuis le 01/26/14
510 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 9-25, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 9-25, Maness Winter 2014
CPSU-MANESS-W14S9G25
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 142
