Introduction
If the 'on'/'off' switch of the device is stuck in the 'off' position, the device will not turn on. This guide will show how to access and replace the switch from within.
Place the meter face down, so the back panel and screws can be seen.
  • Place the meter face down, so the back panel and screws can be seen.
Ajouter un commentaire
Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver. Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
  • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
Remove the back panel of the device by lifting upward.
  • Remove the back panel of the device by lifting upward.
  • Remove the battery from the meter before continuing.
Remove the four 7mm Phillips screws holding the circuit board in place. Remove the four 7mm Phillips screws holding the circuit board in place.
  • Remove the four 7mm Phillips screws holding the circuit board in place.
Gently lift the circuit board away from the device casing.
  • Gently lift the circuit board away from the device casing.
  • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
The 'on'/'off' switch is located directly beneath the dial.
  • The 'on'/'off' switch is located directly beneath the dial.
Gently remove switch from device by lifting upward.
  • Gently remove switch from device by lifting upward.
  • Either clean or replace switch.
3 autre(s) ont terminé cette réparation.
Rebekah Allison
Membre depuis le 13/10/2014
133 Réputation
1 tutoriel rédigé
Équipe
Clemson, Team 2-4, Benson Fall 2014 Membre de l'équipe Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 20
Total : 687
