Introduction
If the dial cannot spin then it is likely that the ball bearings are missing or not properly lubricated.
Place the meter face down, so the back panel and screws can be seen.
  • Place the meter face down, so the back panel and screws can be seen.
Ajouter un commentaire
Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver. Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
  • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
Remove the back panel of the device by lifting upward.
  • Remove the back panel of the device by lifting upward.
  • Remove the battery from the meter before continuing.
Remove the four 7mm Phillips screws holding the circuit board in place. Remove the four 7mm Phillips screws holding the circuit board in place.
  • Remove the four 7mm Phillips screws holding the circuit board in place.
Gently lift the circuit board away from the device casing.
  • Gently lift the circuit board away from the device casing.
  • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
The dial is located in the central part of the device.
  • The dial is located in the central part of the device.
Carefully remove dial from device by lifting upward.
  • Carefully remove dial from device by lifting upward.
  • Clean existing dial or replace if necessary.
  • Take care not to lose the small ball bearings.
Locate ball bearings. Carefully remove.
  • Locate ball bearings. Carefully remove.
  • If both ball bearings are still present, try lubricating ball bearings with multi-use lubricant.
  • If one or both ball bearings are missing, simply replace.
2 autre(s) ont terminé cette réparation.
Anna Kihm
Membre depuis le 13/10/2014
793 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 2-4, Benson Fall 2014 Membre de l'équipe Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 11
Total : 446
