Introduction
If a Google Chromecast is dropped or overheated, there is a chance the internal metal shiedling may lose integrity. The external case replacement guide should be consulted prior to this guide.
Pièces
Aucune pièce nécessaire.
Place the Google Chromecast face down (with text not showing) on a flat surface.
  • Place the Google Chromecast face down (with text not showing) on a flat surface.
  • Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
Ajouter un commentaire
Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
  • Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
Remove the circuit board, lifting from the HDMI port.
  • Remove the circuit board, lifting from the HDMI port.
  • The power button may become dislodged.
Pry the plastic clamp from the heatsink.
  • Pry the plastic clamp from the heatsink.
    • Do not pry too hard to avoid breaking the clamp.
Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case. The adhesive's strength may vary, and force should be applied gently until it becomes dislodged to avoid breaking the device.
  • Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case.
    • The adhesive's strength may vary, and force should be applied gently until it becomes dislodged to avoid breaking the device.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Pry the metal extensions from the HDMI port.
  • Pry the metal extensions from the HDMI port.
Insert the plastic opening tool into the corner next to the metal extensions, prying upward.
  • Insert the plastic opening tool into the corner next to the metal extensions, prying upward.
Pry the metal piece around the metal, extruding it from the internal components.
  • Pry the metal piece around the metal, extruding it from the internal components.
Completely remove the top metal casing to expose the internal components.
  • Completely remove the top metal casing to expose the internal components.
Pry metal extensions from the HDMI port on the posterior side of the device.
  • Pry metal extensions from the HDMI port on the posterior side of the device.
Insert the plastic opening tool under the corner to pry off the metal casing from the internal components.
  • Insert the plastic opening tool under the corner to pry off the metal casing from the internal components.
Continue prying around the device, removing the metal piece from the internal components.
  • Continue prying around the device, removing the metal piece from the internal components.
Completely remove the bottom metal piece.
  • Completely remove the bottom metal piece.
Cameron Heiges
Membre depuis le 21/03/2018
473 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S5-G6, Baechle Spring 2018 Membre de l'équipe IUPUI, Team S5-G6, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G6
3 membres
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 39
Total : 54
