Aller au contenu principal
Cirago M9030 Button Module Replacement
Ce dont vous avez besoin
  1. Cirago M9030 Button Module Replacement, Cover: étape 1, image 1 de 1
    • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
  2. Cirago M9030 Button Module Replacement: étape 2, image 1 de 1
    • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
    • Remove the warranty sticker across the bottom.
  3. Cirago M9030 Button Module Replacement: étape 3, image 1 de 2 Cirago M9030 Button Module Replacement: étape 3, image 2 de 2
    • Gently take the cover apart using your hands separating the top and bottom.
    • The outer shell is expected to easily come apart.
  4. Cirago M9030 Button Module Replacement, Hard Drive: étape 4, image 1 de 1
    • Make sure that the screen of the device is facing down.
  5. Cirago M9030 Button Module Replacement: étape 5, image 1 de 3 Cirago M9030 Button Module Replacement: étape 5, image 2 de 3 Cirago M9030 Button Module Replacement: étape 5, image 3 de 3
    • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
    • Raise the bottom edge of the hard drive 15 degrees up from the device.
  6. Cirago M9030 Button Module Replacement: étape 6, image 1 de 3 Cirago M9030 Button Module Replacement: étape 6, image 2 de 3 Cirago M9030 Button Module Replacement: étape 6, image 3 de 3
    • Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
  7. Cirago M9030 Button Module Replacement, IDE Connector: étape 7, image 1 de 2 Cirago M9030 Button Module Replacement, IDE Connector: étape 7, image 2 de 2
    • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
  8. Cirago M9030 Button Module Replacement: étape 8, image 1 de 1
    • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
  9. Cirago M9030 Button Module Replacement: étape 9, image 1 de 2 Cirago M9030 Button Module Replacement: étape 9, image 2 de 2
    • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
    • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
  10. Cirago M9030 Button Module Replacement: étape 10, image 1 de 1
    • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
  11. Cirago M9030 Button Module Replacement: étape 11, image 1 de 2 Cirago M9030 Button Module Replacement: étape 11, image 2 de 2
    • Completely remove the IDE connector from the device.
    • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
  12. Cirago M9030 Button Module Replacement, Motherboard: étape 12, image 1 de 2 Cirago M9030 Button Module Replacement, Motherboard: étape 12, image 2 de 2
    • Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard.
    • Completely remove the motherboard.
    • The motherboard should slide out easily.
  13. Cirago M9030 Button Module Replacement, Button Module: étape 13, image 1 de 1
    • Set aside the front cover.
    • Flip over the motherboard.
    • Using the Philips #00 screwdriver, remove the three 4mm long screws holding down the button module.
  14. Cirago M9030 Button Module Replacement: étape 14, image 1 de 3 Cirago M9030 Button Module Replacement: étape 14, image 2 de 3 Cirago M9030 Button Module Replacement: étape 14, image 3 de 3
    • Using the tweezers, lift up the button module to a 180 degree angle.
    • Leave the button module attached by the ribbon.
    • Flip over the motherboard with the button module still attached.
  15. Cirago M9030 Button Module Replacement: étape 15, image 1 de 3 Cirago M9030 Button Module Replacement: étape 15, image 2 de 3 Cirago M9030 Button Module Replacement: étape 15, image 3 de 3
    • Fold the button module over the motherboard.
    • Using the tweezers, remove the ribbon pin.
    • The ribbon pin should snap completely off of the motherboard.
  16. Cirago M9030 Button Module Replacement: étape 16, image 1 de 2 Cirago M9030 Button Module Replacement: étape 16, image 2 de 2
    • The ribbon should easily detach from the motherboard.
Ryan Sutardji
Membre depuis le 06/29/12
171 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 1-4, Regan SU 2012 Membre de l'équipe Cal Poly, Team 1-4, Regan SU 2012
CPSU-REGAN-SU12S1G4
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 970
