Introduction
We will be opening the battery compartment and replacing the two AAA batteries.
Pièces
Aucune pièce nécessaire.
Use the Phillips #00 screwdriver to loosen the 6.8 mm screw. Use the Phillips #00 screwdriver to loosen the 6.8 mm screw.
  • Use the Phillips #00 screwdriver to loosen the 6.8 mm screw.
Ajouter un commentaire
Use the plastic opening tool to pry up the battery compartment cover. Use the plastic opening tool to pry up the battery compartment cover.
  • Use the plastic opening tool to pry up the battery compartment cover.
Once compartment is open, remove the two AAA batteries. Once compartment is open, remove the two AAA batteries. Once compartment is open, remove the two AAA batteries.
  • Once compartment is open, remove the two AAA batteries.
Aaron Farnsworth
Membre depuis le 20/01/2015
116 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 19-1, Blackwell Winter 2015 Membre de l'équipe USF Tampa, Team 19-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G1
4 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 159
