Introduction
You will learn how to take apart the necessary parts of the controller, how to clean the inside, and how certain parts are supposed to aligned or inserted into other parts.
Remove  the 9 external screws (4.8 mm Phillips head) on the back of the controller. Remove the back panel from the controller.
  • Remove the 9 external screws (4.8 mm Phillips head) on the back of the controller.
  • Remove the back panel from the controller.
Ajouter un commentaire
Remove the 3 screws (4.8 mm Phillips head) from the back of the white box. Remove the back panel of the joystick box. There are many small plastic components loose in this box; be careful not to lose these.
  • Remove the 3 screws (4.8 mm Phillips head) from the back of the white box.
  • Remove the back panel of the joystick box.
  • There are many small plastic components loose in this box; be careful not to lose these.
  • Separate the rubber pads and plastic buttons from the controller.
Using a soft cleaning material, clean the plastic buttons. Using a toothpick, clean the pole slot, shown at the right of the Q-Tip.
  • Using a soft cleaning material, clean the plastic buttons.
  • Using a toothpick, clean the pole slot, shown at the right of the Q-Tip.
Using a damp, soft cleaning material, clean the rubber button pads. To ensure that no electrical damage occurs, ensure that you dry the pieces completely after cleaning them.
  • Using a damp, soft cleaning material, clean the rubber button pads.
  • To ensure that no electrical damage occurs, ensure that you dry the pieces completely after cleaning them.
Reinsert the buttons, ensuring that the rubber, cylindrical pieces protruding from the buttons are lined up with their corresponding circuits.
  • Reinsert the buttons, ensuring that the rubber, cylindrical pieces protruding from the buttons are lined up with their corresponding circuits.
Follow these steps in reverse order to reassemble your device.
4 autre(s) ont terminé cette réparation.
Jason Gittler
Membre depuis le 22/07/2013
102 Réputation
1 tutoriel rédigé
Équipe
UC Santa Barbara, Team 1-3, Bradley Spring 2013 Membre de l'équipe UC Santa Barbara, Team 1-3, Bradley Spring 2013
UCSB-BRADLEY-S13S1G3
2 membres
1 tutoriel rédigé
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 44
Total : 2,351
