Introduction
Wall outlets for electricity had only a single socket when first introduced in 1930s America. Those evolved to the double-socket or duplex outlet wall plates we now take for granted. Had they not evolved, we would all have extension cords coming from the single sockets to split the incoming electricity, just as connector cables (with splitters) still split the incoming broadband cable signal today. Now more than forty years old, the cable TV industry is evolving to duplex style wall plates for its customers' incoming cable signal.
Pièces
Aucune pièce nécessaire.
...you know the old school setup, a connector cable coming out of the wall attached to a splitter—both lying on the floor collecting dust. Unscrew the cable extension from the wall plate; you're not going to need it after this.
  • ...you know the old school setup, a connector cable coming out of the wall attached to a splitter—both lying on the floor collecting dust.
  • Unscrew the cable extension from the wall plate; you're not going to need it after this.
Ajouter un commentaire
Use an appropriate screwdriver to remove the wall plate mounting screws. This wall plate used flathead screws, but yours could be Phillips.
  • Use an appropriate screwdriver to remove the wall plate mounting screws. This wall plate used flathead screws, but yours could be Phillips.
Remove the existing wall plate by unscrewing it from the coaxial cable in the wall.
  • Remove the existing wall plate by unscrewing it from the coaxial cable in the wall.
Connect the new two-way splitter plate to the coaxial cable.
  • Connect the new two-way splitter plate to the coaxial cable.
Replace the mounting screws and tighten them with the proper screwdriver. Replace the mounting screws and tighten them with the proper screwdriver.
  • Replace the mounting screws and tighten them with the proper screwdriver.
Install the outer wall plate and tighten the mounting screws with the appropriate screwdriver. Enjoy your reclaimed floor space and futuristic wall plate!
  • Install the outer wall plate and tighten the mounting screws with the appropriate screwdriver.
  • Enjoy your reclaimed floor space and futuristic wall plate!
Scary flashback (especially, for cable-management aficionados).
  • Scary flashback (especially, for cable-management aficionados).
Ligne d'arrivée
2 autre(s) ont terminé cette réparation.
Advanamics
Membre depuis le 03/09/2011
217 Réputation
1 tutoriel rédigé
I already have a wall plate with one cable output(for my modem) can I connect the splitter to this wall plate or I have to remove the plate and connect the other cable behind the wall plate
jinkuntan007 - Réponse
The reason why coaxial wall plates only have one coaxial jack is because using a two-way splitter divides the signal by two. That’s right, the signal strength on both sockets is 50% weaker. It doesn’t matter whether there is something connected to the other socket or not, or what’s connected to it, it’s still half as strong as it was before the splitter on both sockets. In fact, leaving an unused socket open is even worse as it let interference in. Coaxial works with a center conductor that carries the signal, and an outer shielded that protects against EMI and it needs to be sealed (i.e., no open jack, unconnected cable, cut cable, etc.). Any unused jacks or cables should have a 75 ohm termination. So that’s why coaxial jacks only has one socket, and why cable guys only put splitter when really needed. They fix problems every day by people who thought it would be a good idea to put splitters everywhere, and use cheap gold-painted splitters like the one in the tutorial on top of that.
hc_kev - Réponse
Voir les statistiques:
Dernières 24 heures : 10
7 derniers jours : 76
30 derniers jours : 379
Total : 26,217
