Aller au contenu principal
Coby DVD-R11000 Circuit Boards Replacement
Ce dont vous avez besoin
  1. Coby DVD-R11000 Circuit Boards Replacement, Outer Casing: étape 1, image 1 de 3 Coby DVD-R11000 Circuit Boards Replacement, Outer Casing: étape 1, image 2 de 3 Coby DVD-R11000 Circuit Boards Replacement, Outer Casing: étape 1, image 3 de 3
    • Remove the four 1cm screws, two on each side, of the DVD player with the Phillips #1 screwdriver.
    • Remove the five 1cm screws on the back of the DVD player with the Phillips #1 screwdriver.
    • It is not required to remove the other seven screws in the middle between the I/O ports.
  2. Coby DVD-R11000 Circuit Boards Replacement: étape 2, image 1 de 3 Coby DVD-R11000 Circuit Boards Replacement: étape 2, image 2 de 3 Coby DVD-R11000 Circuit Boards Replacement: étape 2, image 3 de 3
    • Position the DVD player so that the back is facing you
    • Grab underneath the sides of the DVD player and lift the front of it upwards.
    • Carefully pull the top of the casing off
  3. Coby DVD-R11000 Circuit Boards Replacement, 3-Pin Power Cable: étape 3, image 1 de 2 Coby DVD-R11000 Circuit Boards Replacement, 3-Pin Power Cable: étape 3, image 2 de 2
    • Gently pinch the 3-pin white adapter of the wire connecting the power cord to the circuit board.
    • Remove the wire from the circuit board.
  4. Coby DVD-R11000 Circuit Boards Replacement, Circuit Boards: étape 4, image 1 de 2 Coby DVD-R11000 Circuit Boards Replacement, Circuit Boards: étape 4, image 2 de 2
    • Position the DVD player so that the side with golden circuit board, where the power cord was plugged into, is closest to you.
    • Remove the black wire with the 6-pin white adapter, which is adjacent to the other three pin adapter wires on the golden circuit board.
  5. Coby DVD-R11000 Circuit Boards Replacement: étape 5, image 1 de 3 Coby DVD-R11000 Circuit Boards Replacement: étape 5, image 2 de 3 Coby DVD-R11000 Circuit Boards Replacement: étape 5, image 3 de 3
    • Position the DVD player so that the back panel is facing you.
    • Remove the three wires with the white pin adapters from the golden circuit board.
  6. Coby DVD-R11000 Circuit Boards Replacement: étape 6, image 1 de 3 Coby DVD-R11000 Circuit Boards Replacement: étape 6, image 2 de 3 Coby DVD-R11000 Circuit Boards Replacement: étape 6, image 3 de 3
    • Remove the four half inch screws, located at each corner of the golden circuit board, using the Phillips #1 screwdriver.
    • Place the blue plastic tool opener underneath the side of the circuit board and carefully remove it from the DVD player.
  7. Coby DVD-R11000 Circuit Boards Replacement: étape 7, image 1 de 3 Coby DVD-R11000 Circuit Boards Replacement: étape 7, image 2 de 3 Coby DVD-R11000 Circuit Boards Replacement: étape 7, image 3 de 3
    • Position the DVD player so that the front is facing you.
    • Using the tweezers and the blue plastic opening tool, disconnect the ribbon cables from the green circuit board where the I/O ports are attach to.
  8. Coby DVD-R11000 Circuit Boards Replacement: étape 8, image 1 de 3 Coby DVD-R11000 Circuit Boards Replacement: étape 8, image 2 de 3 Coby DVD-R11000 Circuit Boards Replacement: étape 8, image 3 de 3
    • Remove the three wires with the white pin adapters from the green circuit board that you just disconnected the ribbon wires from.
  9. Coby DVD-R11000 Circuit Boards Replacement: étape 9, image 1 de 3 Coby DVD-R11000 Circuit Boards Replacement: étape 9, image 2 de 3 Coby DVD-R11000 Circuit Boards Replacement: étape 9, image 3 de 3
    • Remove the seven 1cm screws located on the back panel of the outer casing, in between the I/O ports, with the Phillips #1 screwdriver
    • Grab the sides of the back panel and remove it from the DVD player.
  10. Coby DVD-R11000 Circuit Boards Replacement: étape 10, image 1 de 2 Coby DVD-R11000 Circuit Boards Replacement: étape 10, image 2 de 2
    • Remove the two 1cm screws that are circled in red.
Andrew
Membre depuis le 10/22/14
501 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-6, Shastany Fall 2014 Membre de l'équipe UMass Dartmouth, Team 1-6, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G6
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 520
