Press the eject button to view the laser inside. Using the blue plastic tool and the tweezers, remove the ribbon cable. Using the blue plastic tool and the tweezers, remove the ribbon cable.
  • Press the eject button to view the laser inside.
  • Using the blue plastic tool and the tweezers, remove the ribbon cable.
Ajouter un commentaire
Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver. Do not lift the top of the DVD player too quickly because there are wires attached on the inside. Pry the top of the device open from the right side where the buttons are located.
  • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
  • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
  • Pry the top of the device open from the right side where the buttons are located.
When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them. Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board. Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
  • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
Position the DVD player so that the power and AVI ports are facing you. Pull the white cable with the blue adapters off of the circuit boards. Pull the white cable with the blue adapters off of the circuit boards.
  • Position the DVD player so that the power and AVI ports are facing you.
  • Pull the white cable with the blue adapters off of the circuit boards.
Yufay Chow
Membre depuis le 23/01/2012
92 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 10-36, Amido Winter 2012 Membre de l'équipe Cal Poly, Team 10-36, Amido Winter 2012
CPSU-AMIDO-W12S10G36
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 789
