Introduction
A guide on how to remove the LED Cover.
Pièces
Aucune pièce nécessaire.
Turn the laptop bottom side up with the rear panel facing forward.
  • Turn the laptop bottom side up with the rear panel facing forward.
Ajouter un commentaire
Remove the two T8 Torx screws that secure the LED cover to the base enclosure.
  • Remove the two T8 Torx screws that secure the LED cover to the base enclosure.
Turn the laptop top side up with the front facing forward. Open the screen.
  • Turn the laptop top side up with the front facing forward. Open the screen.
Locate the F1 and F2 keys near the top left corner of the keyboard.
  • Locate the F1 and F2 keys near the top left corner of the keyboard.
While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
Locate the Pause and Scroll keys near the top right corner of the keyboard.
  • Locate the Pause and Scroll keys near the top right corner of the keyboard.
While holding the Pause and Scroll keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  • While holding the Pause and Scroll keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover. Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
  • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
kim
Membre depuis le 14/04/2010
47 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 29-74, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 29-74, Johann Spring 2010
CPSU-JOHANN-S10S29G74
3 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 2,473
