Introduction
This guide will build off of the Housing and Power Cord Removal guides to remove and replace the motherboard.
Remove the Philips #1 28 mm.
  • Remove the Philips #1 28 mm.
  • Make sure device is unplugged and cool before attempting to replace parts.
Ajouter un commentaire
Remove the Philips #1 22 mm screws.
  • Remove the Philips #1 22 mm screws.
Pry off the housing using a plastic spudger. Pry off the housing using a plastic spudger. Pry off the housing using a plastic spudger.
  • Pry off the housing using a plastic spudger.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Pull power chord out.
  • Pull power chord out.
Heat up your soldering gun and desolder the red wire from the motherboard as shown.
  • Heat up your soldering gun and desolder the red wire from the motherboard as shown.
  • Note the location of wire attachment.
With your soldering gun, desolder the white wire from the motherboard as shown.
  • With your soldering gun, desolder the white wire from the motherboard as shown.
Once both wires are desoldered the motherboard can be removed.
  • Once both wires are desoldered the motherboard can be removed.
To reassemble your device, follow these instructions in reverse order, making sure to resolder the wires correctly into the replacement motherboard.
Jonathon Bruer
Membre depuis le 09/11/2017
553 Réputation
5 tutoriels rédigés
Équipe
IUPUI, Team S7-G5, Baechle Fall 2017 Membre de l'équipe IUPUI, Team S7-G5, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G5
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 64
