Introduction
If your Connect Four Electronic Handheld does not make any sound, you may need to replace the speaker. This replacement guide will show you how to remove the back casing and remove the speaker. In addition, this guide will also show you how to re-solder the speaker wires.
Make sure the Connect Four Electronic Handheld is off. There is no off button, so you will need to let it shut off automatically.
  • Make sure the Connect Four Electronic Handheld is off. There is no off button, so you will need to let it shut off automatically.
Ajouter un commentaire
Take a Phillips head screwdriver and remove the (9.1mm length) #2 screw in the middle of the battery casing. Slide the cover off and remove the battery.
  • Take a Phillips head screwdriver and remove the (9.1mm length) #2 screw in the middle of the battery casing.
  • Slide the cover off and remove the battery.
Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place. Carefully remove the back casing.
  • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
  • Carefully remove the back casing.
  • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
If the speaker is in working condition, but the wires are broken or disconnected, skip this step and move on to step 5. Locate the speaker on the back casing. Using a spudger, wedge the speaker out of its place until it slides out.
  • If the speaker is in working condition, but the wires are broken or disconnected, skip this step and move on to step 5.
  • Locate the speaker on the back casing.
  • Using a spudger, wedge the speaker out of its place until it slides out.
  • Take the replacement speaker and wedge it back into its space.
Using a soldering iron, solder both red wires to their appropriate connections.
  • Using a soldering iron, solder both red wires to their appropriate connections.
  • Be extremely careful when using a soldering iron! Contact with the tip could cause severe burns.
Wil
Membre depuis le 22/10/2014
319 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team 8-11, Williams Fall 2014 Membre de l'équipe Baylor, Team 8-11, Williams Fall 2014
BU-WILLIAMS-F14S8G11
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 110
