Introduction
Often times it is only necessary to replace the carbon brushes, not the motor. Carbon brushes experience a lot of friction, and replacement is generally expected over time. Ensure your saw is unplugged before beginning the repair
Using a flathead screwdriver, remove the brush caps on the outer casing of the saw near the motor. Using a flathead screwdriver, remove the brush caps on the outer casing of the saw near the motor.
  • Using a flathead screwdriver, remove the brush caps on the outer casing of the saw near the motor.
Ajouter un commentaire
Using a Phillips #00 screwdriver or a small diameter nail, carefully pull out the washer.
  • Using a Phillips #00 screwdriver or a small diameter nail, carefully pull out the washer.
    • The washer is seurely held in place and may require force to remove
After the washers are removed, gently grab the old brushes and remove them from the motor.
  • After the washers are removed, gently grab the old brushes and remove them from the motor.
    • When reassembling make sure the curvature of the brushes match curvature of the motor.
Riley Hilliker
Membre depuis le 14/10/2014
546 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 4-47, Amido Fall 2014 Membre de l'équipe Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 18
Total : 522
