Introduction
WARNING: Once the power cord has been identified as the item that needs replacement, make sure that the device is disconnected from any power supply.
Remove the two 1" Phillips screws using a #1 Phillips screwdriver.
  • Remove the two 1" Phillips screws using a #1 Phillips screwdriver.
  • Remove the three 1/2" Phillips screws using a #1 Phillips screwdriver.
  • Once the five screws are removed, lift the handle cover from the saw.
  • Each screw has a corresponding nut on the opposite side of the power saw
Ajouter un commentaire
Remove the 1/2" Phillips screw that is securing the switch using a Phillips #1 screwdriver.
  • Remove the 1/2" Phillips screw that is securing the switch using a Phillips #1 screwdriver.
Using a Phillips #00 screwdriver or a small diameter screwdriver, gently insert it into the leads. When the screwdriver is inserted into the lead, it will release the wire. The leads are where the black and white wires from the power cord are plugged in.
  • Using a Phillips #00 screwdriver or a small diameter screwdriver, gently insert it into the leads. When the screwdriver is inserted into the lead, it will release the wire.
    • The leads are where the black and white wires from the power cord are plugged in.
  • Release both the black and white wires and gently pull them from the leads.
  • To install the new cord, insert the wires of the new cord in the same way that they were removed.
Riley Hilliker
Membre depuis le 14/10/2014
546 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 4-47, Amido Fall 2014 Membre de l'équipe Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 206
