Aller au contenu principal
Craftsman Model 315.10721 Table Guard Replacement
Ce dont vous avez besoin
  1. Craftsman Model 315.10721 Table Guard Replacement, Table Guard: étape 1, image 1 de 1
    • Using a flathead screwdriver, remove the 1/2" flathead screw to allow the table guard to pivot.
  2. Craftsman Model 315.10721 Table Guard Replacement: étape 2, image 1 de 1
    • Pivot the table guard from its upright position to an angle.
    • Using a Phillips #1 screwdriver, remove the 1" Phillips screw and the nut on the opposite side.
  3. Craftsman Model 315.10721 Table Guard Replacement: étape 3, image 1 de 1
    • Using the Phillips #1 screwdriver, remove eight 1" Philips screws from the main case.
    • Carefully remove the main case to expose the inside of the saw.
  4. Craftsman Model 315.10721 Table Guard Replacement: étape 4, image 1 de 1
    • Remove the old table guard by gently lifting it away from the main case.
    • Replace the old table guard with the new one by placing it in the same orientation as the one removed.
Riley Hilliker
Membre depuis le 10/14/14
557 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 4-47, Amido Fall 2014 Membre de l'équipe Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 membres
5 tutoriels rédigés
2 commentaires
Where can I get a replacement table guard???
Roger Coyle - Réponse
Where can I get a replacement table guard for this jig saw????????
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 14
Total : 608
