Introduction
This tutorial will provide the necessary information on how to replace a power cable in the Crosley CR42.
Turn the device around until you are looking at the line-out port. With a cordless drill or Phillips #0 screwdriver, remove the ten 12-mm screws.
  • Turn the device around until you are looking at the line-out port.
  • With a cordless drill or Phillips #0 screwdriver, remove the ten 12-mm screws.
Ajouter un commentaire
Gently remove the back of the device. It should be connected by two wires. Gently remove the back of the device. It should be connected by two wires. Gently remove the back of the device. It should be connected by two wires.
  • Gently remove the back of the device. It should be connected by two wires.
Gently remove both wires. After de-threading the antenna wire, remove the back of the device and set it aside. After de-threading the antenna wire, remove the back of the device and set it aside.
  • Gently remove both wires.
  • After de-threading the antenna wire, remove the back of the device and set it aside.
Locate where the power cable connects to the device. Pick up the device and locate the screw holding the small black peg to the device. Unscrew it and set the screw aside. Pick up the device and locate the screw holding the small black peg to the device. Unscrew it and set the screw aside.
  • Locate where the power cable connects to the device.
  • Pick up the device and locate the screw holding the small black peg to the device. Unscrew it and set the screw aside.
With the pliers, remove the wire connectors. You may need to be forceful It is wise to attach a marking in order to recognize how the wires should be reattached. It is wise to attach a marking in order to recognize how the wires should be reattached.
  • With the pliers, remove the wire connectors. You may need to be forceful
  • It is wise to attach a marking in order to recognize how the wires should be reattached.
Pull apart both groups of wires. After getting your replacement power cord, make sure you recognize how the wires should reattach. After getting your replacement power cord, make sure you recognize how the wires should reattach.
  • Pull apart both groups of wires.
  • After getting your replacement power cord, make sure you recognize how the wires should reattach.
Twist the connecting wires together. Attach the twist-on wire connectors to the exposed wires. Attach the twist-on wire connectors to the exposed wires.
  • Twist the connecting wires together.
  • Attach the twist-on wire connectors to the exposed wires.
Eric Dybsetter
Membre depuis le 26/01/2014
142 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 1-38, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 1-38, Maness Winter 2014
CPSU-MANESS-W14S1G38
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 4
7 derniers jours : 25
30 derniers jours : 84
Total : 2,875
