Introduction
Removing the back panel requires taking of the top panel first. Then, you must remove four more screws on the back.
Pièces
Aucune pièce nécessaire.
Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD. Unplug the DVD player from the wall socket.
  • Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD.
  • Unplug the DVD player from the wall socket.
  • Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
Ajouter un commentaire
Remove the top panel of the DVD Player by: Sliding the top panel backwards.
  • Remove the top panel of the DVD Player by:
    • Sliding the top panel backwards.
    • Gently lifting the back of the top panel up.
Remove the remaining screws on the back of the DVD player: There will be four 15 mm screws and two 6.3 mm screws.
  • Remove the remaining screws on the back of the DVD player:
    • There will be four 15 mm screws and two 6.3 mm screws.
Remove the back panel by:
  • Remove the back panel by:
    • Lifting up on the back panel.
    • Pulling the back panel backwards from the DVD player.
Chris Menezes
Membre depuis le 07/04/2014
626 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 6-5, Forte Spring 2014 Membre de l'équipe Cal Poly, Team 6-5, Forte Spring 2014
CPSU-FORTE-S14S6G5
5 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 278
