Aller au contenu principal
CyberHome CH-DVD 300 Power Supply Replacement
Ce dont vous avez besoin
  1. CyberHome CH-DVD 300 Power Supply Replacement, Top Panel: étape 1, image 1 de 2 CyberHome CH-DVD 300 Power Supply Replacement, Top Panel: étape 1, image 2 de 2
    • Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD.
    • Unplug the DVD player from the wall socket.
    • Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
  2. CyberHome CH-DVD 300 Power Supply Replacement: étape 2, image 1 de 2 CyberHome CH-DVD 300 Power Supply Replacement: étape 2, image 2 de 2
    • Remove the top panel of the DVD Player by:
    • Sliding the top panel backwards.
    • Gently lifting the back of the top panel up.
  3. CyberHome CH-DVD 300 Power Supply Replacement, Power Supply: étape 3, image 1 de 3 CyberHome CH-DVD 300 Power Supply Replacement, Power Supply: étape 3, image 2 de 3 CyberHome CH-DVD 300 Power Supply Replacement, Power Supply: étape 3, image 3 de 3
    • Orient the device to locate the power supply board on the far right corner. Use needle nose pliers to pull the white connector from the power supply board.
    • The power supply board is connected directly to the power cord. This is not the same thing as the mother board.
3 autres ont terminé cette réparation.
Chris Menezes
Membre depuis le 04/07/14
654 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 6-5, Forte Spring 2014 Membre de l'équipe Cal Poly, Team 6-5, Forte Spring 2014
CPSU-FORTE-S14S6G5
5 membres
5 tutoriels rédigés
8 commentaires
Mine had a bad 2200uf 10v capacitor… I replaced it and the player works fine.
Robert Brackett - Réponse
What and where is that located please?
Kealani Rowe -
So what capacitor have u replaced ?
semyonaxelrod -
I need another power supply board. Mine has 4 blown Capacitors and do not know if any resisters or diodes or small capacitors are bad because I have now testing tools to check them. Just what I see with eyes. Am a retired electronics professional (79) and know what I am doing. Please let me know if I can get a power supply board and the cost. Thank You .
Glennie Waters - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 17
Total : 3,988
