Pièces
Aucune pièce nécessaire.
Remove the two 9.65 mm screws on the back cover using the Philips head PH00 screw driver.
  • Remove the two 9.65 mm screws on the back cover using the Philips head PH00 screw driver.
Ajouter un commentaire
Remove the back casing to expose the circuit board.
  • Remove the back casing to expose the circuit board.
Detach the gray antenna wires by gently pulling on the side closest to the circuit board.
  • Detach the gray antenna wires by gently pulling on the side closest to the circuit board.
Detach the speaker wire by gently pulling on the side closest to the body of the camera.
  • Detach the speaker wire by gently pulling on the side closest to the body of the camera.
Remove the two 7.25 mm screws  using the Ph00  head.
  • Remove the two 7.25 mm screws using the Ph00 head.
Remove the back grey speaker plate
  • Remove the back grey speaker plate
Remove the speaker by gently pulling on the wire near the speaker.
  • Remove the speaker by gently pulling on the wire near the speaker.
Collyn Dodge
Membre depuis le 21/03/2018
305 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S4-G2, Baechle Spring 2018 Membre de l'équipe IUPUI, Team S4-G2, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G2
3 membres
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 39
