Introduction
The power supply switch turns power to the projector on and off. If the projector is not turning on, the power supply switch may need to be replaced.
Make sure the projector is unplugged before starting Place the projector upside down to access the screws on the bottom.
  • Make sure the projector is unplugged before starting
  • Place the projector upside down to access the screws on the bottom.
  • Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
Ajouter un commentaire
Flip the projector over and then remove the cover by lifting it up.
  • Flip the projector over and then remove the cover by lifting it up.
Remove the three 6mm PH2 phillips head screws. Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out. Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
  • Remove the three 6mm PH2 phillips head screws.
  • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Disconnect the three wire connectors.  Grasp both sides of the connector and pull apart. Keep the connector parallel to the mother board to avoid breaking the solder connection. Lift the motherboard up and place it out of the way.
  • Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
  • Keep the connector parallel to the mother board to avoid breaking the solder connection.
  • Lift the motherboard up and place it out of the way.
Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out. Lift the aluminum heat sink up to remove it from the projector. The motherboard is already removed in this step.
  • Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
  • Lift the aluminum heat sink up to remove it from the projector.
  • The motherboard is already removed in this step.
Remove the two 9mm PH2 phillips head screws. Lift the mirror behind the power supply circuit out to gain access to the circuit board. Lift the mirror behind the power supply circuit out to gain access to the circuit board.
  • Remove the two 9mm PH2 phillips head screws.
  • Lift the mirror behind the power supply circuit out to gain access to the circuit board.
Lift the power supply circuit board out of the projector. Disconnect the cable connector by pulling the two sides of the connector apart.
  • Lift the power supply circuit board out of the projector.
  • Disconnect the cable connector by pulling the two sides of the connector apart.
  • Keep the connector parallel to the circuit board to avoid breaking the solder connection.
Using the small plastic splunger, press in on the two latches on the sides of the power supply switch, then push it out of the case. Using the small plastic splunger, press in on the two latches on the sides of the power supply switch, then push it out of the case. Using the small plastic splunger, press in on the two latches on the sides of the power supply switch, then push it out of the case.
  • Using the small plastic splunger, press in on the two latches on the sides of the power supply switch, then push it out of the case.
John Russell
Membre depuis le 14/02/2018
747 Réputation
9 tutoriels rédigés
Équipe
USF Tampa, Team S5-G3, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S5-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S5G3
3 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 21
