Aller au contenu principal
DBPOWER RD-810 Speaker Replacement
Ce dont vous avez besoin
  1. DBPOWER RD-810 Speaker Replacement, Top Cover: étape 1, image 1 de 2 DBPOWER RD-810 Speaker Replacement, Top Cover: étape 1, image 2 de 2
    • Make sure the projector is unplugged before starting
    • Place the projector upside down to access the screws on the bottom.
    • Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
  2. DBPOWER RD-810 Speaker Replacement: étape 2, image 1 de 1
    • Flip the projector over and then remove the cover by lifting it up.
  3. DBPOWER RD-810 Speaker Replacement, Motherboard and LED Bulb: étape 3, image 1 de 3 DBPOWER RD-810 Speaker Replacement, Motherboard and LED Bulb: étape 3, image 2 de 3 DBPOWER RD-810 Speaker Replacement, Motherboard and LED Bulb: étape 3, image 3 de 3
    • Remove the three 6mm PH2 phillips head screws.
    • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
  4. DBPOWER RD-810 Speaker Replacement: étape 4, image 1 de 3 DBPOWER RD-810 Speaker Replacement: étape 4, image 2 de 3 DBPOWER RD-810 Speaker Replacement: étape 4, image 3 de 3
    • Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
    • Keep the connector parallel to the mother board to avoid breaking the solder connection.
    • Lift the motherboard up and place it out of the way.
  5. DBPOWER RD-810 Speaker Replacement: étape 5, image 1 de 3 DBPOWER RD-810 Speaker Replacement: étape 5, image 2 de 3 DBPOWER RD-810 Speaker Replacement: étape 5, image 3 de 3
    • Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
    • Lift the aluminum heat sink up to remove it from the projector.
    • The motherboard is already removed in this step.
  6. DBPOWER RD-810 Speaker Replacement, Power Supply Circuit: étape 6, image 1 de 3 DBPOWER RD-810 Speaker Replacement, Power Supply Circuit: étape 6, image 2 de 3 DBPOWER RD-810 Speaker Replacement, Power Supply Circuit: étape 6, image 3 de 3
    • Remove the two 9mm PH2 phillips head screws.
    • Lift the mirror behind the power supply circuit out to gain access to the circuit board.
  7. DBPOWER RD-810 Speaker Replacement: étape 7, image 1 de 2 DBPOWER RD-810 Speaker Replacement: étape 7, image 2 de 2
    • Lift the power supply circuit board out of the projector.
    • Disconnect the cable connector by pulling the two sides of the connector apart.
    • Keep the connector parallel to the circuit board to avoid breaking the solder connection.
  8. DBPOWER RD-810 Speaker Replacement, Speaker: étape 8, image 1 de 2 DBPOWER RD-810 Speaker Replacement, Speaker: étape 8, image 2 de 2
    • Pull gently on the speaker to break the glue bond, then lift the speaker out of the way.
    • Do not pull on the wires while trying to break the glue bond.
John Russell
Membre depuis le 02/14/18
914 Réputation
9 tutoriels rédigés
Équipe
USF Tampa, Team S5-G3, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S5-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S5G3
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 317
