Aller au contenu principal
DBPOWER T20 Lens Replacement
Ce dont vous avez besoin
  1. DBPOWER T20 Lens Replacement, DBPOWER T20 Disassembly: étape 1, image 1 de 1
    • Flip the device and lay flat.
  2. DBPOWER T20 Lens Replacement: étape 2, image 1 de 1
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Lens Replacement: étape 3, image 1 de 3 DBPOWER T20 Lens Replacement: étape 3, image 2 de 3 DBPOWER T20 Lens Replacement: étape 3, image 3 de 3
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Lens Replacement: étape 4, image 1 de 1
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
  5. DBPOWER T20 Lens Replacement: étape 5, image 1 de 2 DBPOWER T20 Lens Replacement: étape 5, image 2 de 2
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
  6. DBPOWER T20 Lens Replacement: étape 6, image 1 de 3 DBPOWER T20 Lens Replacement: étape 6, image 2 de 3 DBPOWER T20 Lens Replacement: étape 6, image 3 de 3
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Lens Replacement: étape 7, image 1 de 2 DBPOWER T20 Lens Replacement: étape 7, image 2 de 2
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
  8. DBPOWER T20 Lens Replacement: étape 8, image 1 de 1
    • Raise motherboard by lifting sideways and then up to avoid the ports.
  9. DBPOWER T20 Lens Replacement: étape 9, image 1 de 2 DBPOWER T20 Lens Replacement: étape 9, image 2 de 2
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Lens Replacement: étape 10, image 1 de 2 DBPOWER T20 Lens Replacement: étape 10, image 2 de 2
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
  11. DBPOWER T20 Lens Replacement, Lens: étape 11, image 1 de 1
    • The lamp does not need to be removed for this step to be preformed.
  12. DBPOWER T20 Lens Replacement: étape 12, image 1 de 1
    • Detach the keystone adjuster from the lens housing.
    • Lens is on a hinge so it should lift off easily, if it doesn't, adjust by swaying it forward or backward.
  13. DBPOWER T20 Lens Replacement: étape 13, image 1 de 1
    • Remove the rubber foot and warranty sticker found underneath the device.
  14. DBPOWER T20 Lens Replacement: étape 14, image 1 de 2 DBPOWER T20 Lens Replacement: étape 14, image 2 de 2
    • Remove the two screws on the bottom of the device with a J0 screwdriver.
  15. DBPOWER T20 Lens Replacement: étape 15, image 1 de 1
    • Remove the focus-adjustment ring from the lens housing.
3 autres ont terminé cette réparation.
Andrea Espinosa
Membre depuis le 02/15/18
506 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S16-G2, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S16-G2, Boczar Spring 2018
USFT-BOCZAR-S18S16G2
5 membres
5 tutoriels rédigés
3 commentaires
How does the lens parts go together?
Lay - Réponse
I need to know the same
Tremaine Mullins - Réponse
Trying to put my lens back how to install
David Williams - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 31
Total : 2,270
