Aller au contenu principal
DJI Mavic Pro Propeller Replacement
Ce dont vous avez besoin
  1. DJI Mavic Pro Propeller Replacement, Propellers: étape 1, image 1 de 3 DJI Mavic Pro Propeller Replacement, Propellers: étape 1, image 2 de 3 DJI Mavic Pro Propeller Replacement, Propellers: étape 1, image 3 de 3
    • Unfold your Dji Mavic Pro Drone.
  2. DJI Mavic Pro Propeller Replacement: étape 2, image 1 de 3 DJI Mavic Pro Propeller Replacement: étape 2, image 2 de 3 DJI Mavic Pro Propeller Replacement: étape 2, image 3 de 3
    • Push down slightly on the propeller you want to remove.
  3. DJI Mavic Pro Propeller Replacement: étape 3, image 1 de 3 DJI Mavic Pro Propeller Replacement: étape 3, image 2 de 3 DJI Mavic Pro Propeller Replacement: étape 3, image 3 de 3
    • There are 2 types of propellers on a DJI Mavic Pro drone: 1 with a white circle outline (shown in the image) and 1 without.
    • If the propeller you want to remove has a white outline like shown in the image, then turn the propeller counterclockwise to unlock its position.
  4. DJI Mavic Pro Propeller Replacement: étape 4, image 1 de 3 DJI Mavic Pro Propeller Replacement: étape 4, image 2 de 3 DJI Mavic Pro Propeller Replacement: étape 4, image 3 de 3
    • If the propeller you want to remove DOES NOT have a white outline, then turn the propeller clockwise to unlock its position.
  5. DJI Mavic Pro Propeller Replacement: étape 5, image 1 de 3 DJI Mavic Pro Propeller Replacement: étape 5, image 2 de 3 DJI Mavic Pro Propeller Replacement: étape 5, image 3 de 3
    • Pull up the propeller to remove it.
  6. DJI Mavic Pro Propeller Replacement: étape 6, image 1 de 3 DJI Mavic Pro Propeller Replacement: étape 6, image 2 de 3 DJI Mavic Pro Propeller Replacement: étape 6, image 3 de 3
    • To replace the propellers, check to match the propellers with the arm of the drone.
    • The propeller with a white circle will have to be placed on the arm of the drone with a white outline and the propeller without the white circle will be placed on the arm of the drone without the white outline.
  7. DJI Mavic Pro Propeller Replacement: étape 7, image 1 de 3 DJI Mavic Pro Propeller Replacement: étape 7, image 2 de 3 DJI Mavic Pro Propeller Replacement: étape 7, image 3 de 3
    • Align the parts outlined with red with the holes on the arm of the drone outlined by the red.
    • Push the propeller down.
  8. DJI Mavic Pro Propeller Replacement: étape 8, image 1 de 2 DJI Mavic Pro Propeller Replacement: étape 8, image 2 de 2
    • If the propeller has NO white mark (circle) then turn the propeller counterclockwise to lock its position.
    • If the propeller has a white mark (circle) then turn the propeller clockwise to lock its position.
  9. DJI Mavic Pro Propeller Replacement: étape 9, image 1 de 2 DJI Mavic Pro Propeller Replacement: étape 9, image 2 de 2
    • Check to see if the propeller is properly locked into place by slightly pulling it up.
    • If it is locked, then you can safely fly your drone.
Ligne d'arrivée
Sophia Maxine Villarosa
Membre depuis le 01/12/22
196 Réputation
1 tutoriel rédigé
Équipe
York University, Team R-28, Melo-Thaiss Winter 2022 Membre de l'équipe York University, Team R-28, Melo-Thaiss Winter 2022
YORK-MELO-THAISS-W22SRG28
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 28
30 derniers jours : 103
Total : 4,236
