Aller au contenu principal
DJI Phantom 2 Vision+ ESC Removal
Ce dont vous avez besoin
  1. DJI Phantom 2 Vision+ ESC Removal, Remove the battery: étape 1, image 1 de 3 DJI Phantom 2 Vision+ ESC Removal, Remove the battery: étape 1, image 2 de 3 DJI Phantom 2 Vision+ ESC Removal, Remove the battery: étape 1, image 3 de 3
    • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
    • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
  2. DJI Phantom 2 Vision+ ESC Removal, Propellers: étape 2, image 1 de 1
    • Determine if the propellor is clockwise or counter-clockwise rotating.
    • Each arm is labeled with a rotation icon that shows the direction of propellor rotation.
    • If this icon is missing or you can't read it, you can determine the direction of rotation by examining the propellor.
    • A clockwise rotating propellor pushes air down while rotating clockwise, and the opposite is true for a counter-clockwise rotating propellor, and the propellor blade slopes up in the direction of rotation.
  3. DJI Phantom 2 Vision+ ESC Removal, Removing clockwise rotating propellers: étape 3, image 1 de 3 DJI Phantom 2 Vision+ ESC Removal, Removing clockwise rotating propellers: étape 3, image 2 de 3 DJI Phantom 2 Vision+ ESC Removal, Removing clockwise rotating propellers: étape 3, image 3 de 3
    • Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise.
    • Remove the propellor.
  4. DJI Phantom 2 Vision+ ESC Removal, Removing counter-clockwise rotating propellers: étape 4, image 1 de 3 DJI Phantom 2 Vision+ ESC Removal, Removing counter-clockwise rotating propellers: étape 4, image 2 de 3 DJI Phantom 2 Vision+ ESC Removal, Removing counter-clockwise rotating propellers: étape 4, image 3 de 3
    • Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise.
  5. DJI Phantom 2 Vision+ ESC Removal, Case Top Shell: étape 5, image 1 de 2 DJI Phantom 2 Vision+ ESC Removal, Case Top Shell: étape 5, image 2 de 2
    • Remove the following screws from the underside of the Phantom:
    • Twelve 2.0 mm hex bolts
    • Four Phillips #00 screws
  6. DJI Phantom 2 Vision+ ESC Removal: étape 6, image 1 de 2 DJI Phantom 2 Vision+ ESC Removal: étape 6, image 2 de 2
    • Gently lift up the top shell case.
    • Do not attempt to fully remove the top shell. The GPS cable is still attached to the mainboard, avoid lifting the case too high or you may damage this connection.
  7. DJI Phantom 2 Vision+ ESC Removal, Unplug GPS connector and remove case: étape 7, image 1 de 3 DJI Phantom 2 Vision+ ESC Removal, Unplug GPS connector and remove case: étape 7, image 2 de 3 DJI Phantom 2 Vision+ ESC Removal, Unplug GPS connector and remove case: étape 7, image 3 de 3
    • The GPS cable molex connector is located on the backside of the mainboard, near the battery opening.
    • Pull the GPS connector straight up out of its socket.
    • Lift the top shell case up and remove it from the body of the Phantom.
  8. DJI Phantom 2 Vision+ ESC Removal, Desolder motor wires: étape 8, image 1 de 2 DJI Phantom 2 Vision+ ESC Removal, Desolder motor wires: étape 8, image 2 de 2
    • Desolder all three motor wires.
    • When replacing a motor, be sure to solder the new motor in following the same wire color order as when you removed it.
    • The motor spin direction is dependent on the order of the wires, and may not match this image exactly. If you forgot the order, check the arm directly opposite for reference.
  9. DJI Phantom 2 Vision+ ESC Removal: étape 9, image 1 de 1
    • Remove the four 2mm hex motor bolts.
  10. DJI Phantom 2 Vision+ ESC Removal: étape 10, image 1 de 2 DJI Phantom 2 Vision+ ESC Removal: étape 10, image 2 de 2
    • Remove the motor from the motor mount.
  11. DJI Phantom 2 Vision+ ESC Removal, Prepare ESC for removal: étape 11, image 1 de 3 DJI Phantom 2 Vision+ ESC Removal, Prepare ESC for removal: étape 11, image 2 de 3 DJI Phantom 2 Vision+ ESC Removal, Prepare ESC for removal: étape 11, image 3 de 3
    • Cut the zip-tie securing the signal and power cables.
    • Unplug the ESC signal cable molex connector from the ESC.
  12. DJI Phantom 2 Vision+ ESC Removal, Desolder the ESC: étape 12, image 1 de 2 DJI Phantom 2 Vision+ ESC Removal, Desolder the ESC: étape 12, image 2 de 2
    • Desolder the ESC ground and voltage wires from the mainboard.
    • Be careful not to melt the plastic case bottom shell with your soldering iron or damage any electronic components.
    • You can remove in-the-way cables by unplugging them and moving them aside. This will protect them from the warning above.
    • Be sure to plug these cables back in before reassembling your Phantom 2.
  13. DJI Phantom 2 Vision+ ESC Removal, Unsecuring the ESC: étape 13, image 1 de 3 DJI Phantom 2 Vision+ ESC Removal, Unsecuring the ESC: étape 13, image 2 de 3 DJI Phantom 2 Vision+ ESC Removal, Unsecuring the ESC: étape 13, image 3 de 3
    • Remove the two ESC securing screws.
    • The clear plastic LED cover will either drop from the underside or need to be loosened with a plastic spudger.
  14. DJI Phantom 2 Vision+ ESC Removal, Removing the ESC: étape 14, image 1 de 3 DJI Phantom 2 Vision+ ESC Removal, Removing the ESC: étape 14, image 2 de 3 DJI Phantom 2 Vision+ ESC Removal, Removing the ESC: étape 14, image 3 de 3
    • With the ESC no longer secured to the airframe, lift it up and remove it.
8 autres ont terminé cette réparation.
David Hoyt
Membre depuis le 04/09/10
4 023 Réputation
43 tutoriels rédigés
Équipe
Cal Poly, Team 25-89, Amido Spring 2010 Membre de l'équipe Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 membres
63 tutoriels rédigés
Un commentaire
Is it a difference between ESC from different versions (1.0, 2.0 and 3.0) of Phantom 2?
jarbas_sjo - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 14
Total : 6,483
