Introduction
For this project you will need to have the knowledge, and tools necessary to solder. The following link gives instructions on how to solder. Comment souder et dessouder des connexions
Pièces
Aucune pièce nécessaire.
Take plastic opening tools, and find a spot on the back of tablet to lift the back plate. Once back is lifted enough, remove the back of the tablet carefully with fingers Take plastic opening tools, and find a spot on the back of tablet to lift the back plate. Once back is lifted enough, remove the back of the tablet carefully with fingers Take plastic opening tools, and find a spot on the back of tablet to lift the back plate. Once back is lifted enough, remove the back of the tablet carefully with fingers
  • Take plastic opening tools, and find a spot on the back of tablet to lift the back plate. Once back is lifted enough, remove the back of the tablet carefully with fingers
Ajouter un commentaire
Locate battery, and examine wires connected to battery.
  • Locate battery, and examine wires connected to battery.
Carefully remove battery without putting any strain on connected wires. The battery is held to the tablet with adhesive, so be careful not to jerk the battery when it becomes loose. Carefully remove battery without putting any strain on connected wires. The battery is held to the tablet with adhesive, so be careful not to jerk the battery when it becomes loose. Carefully remove battery without putting any strain on connected wires. The battery is held to the tablet with adhesive, so be careful not to jerk the battery when it becomes loose.
  • Carefully remove battery without putting any strain on connected wires. The battery is held to the tablet with adhesive, so be careful not to jerk the battery when it becomes loose.
Use a soldering iron to carefully remove wires from motherboard. Then remove battery. Use a soldering iron to carefully remove wires from motherboard. Then remove battery. Use a soldering iron to carefully remove wires from motherboard. Then remove battery.
  • Use a soldering iron to carefully remove wires from motherboard. Then remove battery.
Kaitlyn Hayes
Membre depuis le 21/01/2015
408 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 5-2, Brown Winter 2015 Membre de l'équipe USF Tampa, Team 5-2, Brown Winter 2015
USFT-BROWN-W15S5G2
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 19
Total : 1,012
