Aller au contenu principal
Dell Inspiron 15-7569 Battery Replacement
Ce dont vous avez besoin
  1. Dell   Inspiron  15-7569 Battery Replacement, Back Cover: étape 1, image 1 de 3 Dell   Inspiron  15-7569 Battery Replacement, Back Cover: étape 1, image 2 de 3 Dell   Inspiron  15-7569 Battery Replacement, Back Cover: étape 1, image 3 de 3
    • Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
    • After removing the screws, remove the back cover using a plastic or metal spudger.
  2. Dell   Inspiron  15-7569 Battery Replacement, Battery: étape 2, image 1 de 3 Dell   Inspiron  15-7569 Battery Replacement, Battery: étape 2, image 2 de 3 Dell   Inspiron  15-7569 Battery Replacement, Battery: étape 2, image 3 de 3
    • Unscrew the (4) four screws surrounding the battery with a Phillips #0 screwdriver.
    • Unplug the cord connected to the battery and remove the battery.
5 autres ont terminé cette réparation.
Matthew Clements
Membre depuis le 10/03/17
546 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S5-G4, Walkup Fall 2017 Membre de l'équipe USF Tampa, Team S5-G4, Walkup Fall 2017
USFT-WALKUP-F17S5G4
4 membres
6 tutoriels rédigés
Un commentaire
Thanks Matthew,
This was a huge help for me. It took just a few minutes, but I spent some time brushing & blowing out the fan & heatsink. Only difference from the instructions is that there are only 2 screws to remove the battery. The other 2 are removed when removing the case. I am grateful for these videos because, otherwise, one is likely to remove extra screws & miss the hidden ones on some products.
Thanks,
Kev
kevs - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 33
Total : 6,195
