Introduction
In this guide, we will show you how to remove and replace the Subwoofer.
Ce dont vous avez besoin
Remove the screws that secure the base cover to the computer base.
Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
Replace the screws that secure the base cover to the computer base.
Disconnect the battery cable from the system-board connector.
Using the battery cable, lift the battery and release it from the tabs on the computer base.
Turn the computer over and open the display as far as possible.
Press and hold the power button for five seconds to ground the system board.
Align the tabs on the NEW battery with the slots on the computer base.
Align the screw holes on the battery with the screw holes on the computer base.
Replace the screws that secure the battery to the computer base.
Connect the battery cable to the system-board connector.
Remove the screws that secure the secondary hard-drive assembly to the computer base.
Carefully lift the secondary hard-drive assembly and then lift the latches to release the secondary hard-drive cable from the system-board connector.
Lift the secondary hard-drive assembly off the computer base.
Remove the screw that secures the secondary hard-drive assembly to the main bracket.
Remove the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
Slide and lift the secondary hard-drive off the secondary hard-drive bracket.
Disconnect the interposer from the secondary hard-drive connector.
Connect the interposer to the secondary hard-drive connector.
Place the NEW secondary hard-drive in the secondary hard-drive bracket.
Align the screw holes on the secondary hard-drive with the screw holes on the secondary hard-drive bracket.
Replace the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
Align the screw hole on the secondary hard-drive assembly with the screw hole on the main bracket.
Replace the screw that secures the secondary hard-drive assembly to the main bracket.
Slide the secondary hard-drive cable into the system-board connector and press down on the connector latches to secure the cable.
Align the screw holes on the secondary hard-drive assembly with the screw holes on the computer base.
Replace the screws that secure the secondary hard-drive assembly to the computer base.
Lift the connector latch and pull the pull-tab to disconnect the status-light board cable from the system-board connector and slide the cable into the slot on the computer base.
Remove the screws that secure the palm -rest assembly to the computer base.
Using a plastic scribe, pry the palm-rest assembly from the computer base.
Carefully lift the palm-rest assembly and turn it over.
Release the connector latches to disconnect the flexi-cable from the system board.
Follow the instructions from step 1 to step 9 in Removing the Keyboard.
Follow the instructions from step 1 to step 4 in Removing the Status-Light Board.
Follow the instructions from step 1 to step 4 in Removing the Speakers.
Follow the instructions from step 1 to step 4 in Removing the Power-Button Board.
Follow the instructions from step 1 to step 4 in Replacing the Power-Button Board.
Follow the instructions from step 1 to step 3 in Replacing the Speakers.
Follow the instructions from step 1 to step 8 in Replacing the Keyboard.
Connect the flexi-cable to the connector on the system board.
Turn the NEW palm-rest assembly over and slide the status-light board cable through the slot on the computer base.
Align the palm-rest assembly over the computer base and snap the palm-rest assembly into place.
Replace the screws that secure the palm-rest assembly to the computer base.
Slide the status-light board cable into the system-board connector and press on the connector latch to secure the cable.
Remove the screws that secure the subwoofer to the computer base.
Disconnect the subwoofer cable from the system-board connector.
Note the subwoofer cable routing and remove it from the routing guide.
Lift the subwoofer along with its cable away from the computer base.
Use the alignment posts on the computer base to keep the NEW subwoofer in place.
Replace the screws that secure the subwoofer to the computer base.
Route the subwoofer cable through the routing guide and connect the cable to the system-board connector.
