Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Dell Alienware 15 Battery Replacement
Ce dont vous avez besoin
    • After turning the computer off, close the display and turn the computer over.
    Demander à FixBot
    Ajouter un commentaire
  1. Dell Alienware 15 Battery Replacement, Remove the Back Panel Screws and Lift: étape 2, image 1 de 1
    • After the computer base (#1) is facing up, use a Philips screwdriver to remove the two captive screws (#2) which hold the base panel (#3) down.
    • Then, use a spudger (#4) to lift up the panel. You can also use your fingernail to lift it as well.
    • After the front has been lifted up a bit, the non-screw side of the panel will need to be slid forward a little to finish lifting out the base panel from the computer.
    Demander à FixBot
  2. Dell Alienware 15 Battery Replacement, Optional: Disconnect the Battery: étape 3, image 1 de 1
    • You don't need to disconnect the laptop's battery if you are only replacing the back panel: only perform this step if you will be handling or replacing the electrical components of the computer.
    • Disconnect the battery cable from the system board by pulling up on the battery connector (#1).
    • Turn the computer back over and open the display to the point where you can press the power button.
    • Press and hold the power button for 4 seconds to ground the system board so that you can safely remove components such as the RAM.
    Demander à FixBot
  3. Dell Alienware 15 Battery Replacement, Memory Securing Clips: étape 4, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
    Demander à FixBot
  4. Dell Alienware 15 Battery Replacement, Remove Memory Module: étape 5, image 1 de 1
    • Slide and remove the memory module from any memory-module slots that you would like to repopulate.
    Demander à FixBot
  5. Dell Alienware 15 Battery Replacement, Adding New Memory Module: étape 6, image 1 de 1
    • Align the notch on the New memory module with the tab on the memory- module slot.
    Demander à FixBot
  6. Dell Alienware 15 Battery Replacement, Firmly Press the Memory Module Down.: étape 7, image 1 de 1
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place. Do this individually for each memory module that is replaced.
    • NOTE : If you do not hear the click, remove the memory module and reinstall it.
    Demander à FixBot
  7. Dell Alienware 15 Battery Replacement, Remove Solid-State screw: étape 8, image 1 de 1
    • CAUTION : Solid-state drives are fragile. Exercise care when handling the solid-state drives, and avoid touching the gold contact pins.
    • CAUTION : To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
    • Remove the screw that secures the solid-state drive to the computer base.
    Demander à FixBot
  8. Dell Alienware 15 Battery Replacement, Slide the Solid-State Drive: étape 9, image 1 de 1
    • Slide and remove the solid-state drive from the solid-state drive slot.
    Demander à FixBot
  9. Dell Alienware 15 Battery Replacement, Slide the Solid-state Drive: étape 10, image 1 de 1
    • Slide the solid-state drive into the solid-state drive slot.
    Demander à FixBot
  10. Dell Alienware 15 Battery Replacement, Align the screw: étape 11, image 1 de 1
    • Align the screw hole on the solid-state drive with the screw hole on the computer base.
    Demander à FixBot
  11. Dell Alienware 15 Battery Replacement, Replace the Screw: étape 12, image 1 de 1
    • Replace the screw that secures the solid-state drive to the computer base.
    Demander à FixBot
  12. Dell Alienware 15 Battery Replacement, Preparations for Removing Cables: étape 13, image 1 de 1
    • Remove the keyboard-backlight cable, keyboard cable, and macro-keys cable from the routing guides (the small plastic tabs) on the computer base.
    • Do not force the cables out of the system board without lifting up the latches that hold them down first. Forcing out cables could result in them snaping or tearing, rendering them unusable.
    • You do not need to remove the hard drive to remove the battery, but it is advisable that you do so if you are concerned about dropping the computer while removing the battery.
    Demander à FixBot
  13. Dell Alienware 15 Battery Replacement, Lift Cable Latches and Remove: étape 14, image 1 de 1
    • Carefully lift the white latches (like #3) and remove all 4 of the keyboard and macro-key cables from their sockets.
    • Don't forget to lift the smaller black latch and remove the macro-key backlight cable (#5) to the right of the other cables!
    Demander à FixBot
  14. Dell Alienware 15 Battery Replacement, Unscrewing the Computer Base: étape 15, image 1 de 1
    • Remove all 15 screws which hold down the computer base. Two screws are located near the RAM slot, while the others are situated mostly around the outside of the computer.
    Demander à FixBot
  15. Dell Alienware 15 Battery Replacement, Press to Remove Palm Rest: étape 16, image 1 de 2 Dell Alienware 15 Battery Replacement, Press to Remove Palm Rest: étape 16, image 2 de 2
    • Open the computer's display and lay the computer down on the back of its open display.
    • Using your finger or a screwdriver, push inside the palm rest release hole (#3 in image 1) to release the palm rest from the tabs that hold it down.
    • Using a plastic scribe, pry up along the edges of the palm-rest assembly. After the palm rest is no longer attached to the computer via any tabs, try lifting up the palm-rest assembly.
    • Make sure that no cables or other fragile objects are still attached to the palm-rest assembly as you pull it out.
    Demander à FixBot
  16. Dell Alienware 15 Battery Replacement, Ready for Battery Removal: étape 17, image 1 de 1
    • If you are only replacing the battery, you do not need to perform this step.
    • Pull the power-button cable horizontally to remove it from the palm rest assembly.
    Demander à FixBot
  17. Dell Alienware 15 Battery Replacement, Remove Speaker Cable: étape 18, image 1 de 1
    • Remove the speaker cable from the routing guides on the battery.
    • Note the front AlienFX LED cable routing and peel off the cable from the battery.
    Demander à FixBot
  18. Dell Alienware 15 Battery Replacement, Remove Batter Screws: étape 19, image 1 de 1
    • Remove the screws that secure the battery to the computer base.
    Demander à FixBot
  19. Dell Alienware 15 Battery Replacement, Remove Battery: étape 20, image 1 de 1
    • Lift the battery off the computer base.
    Demander à FixBot
  20. Dell Alienware 15 Battery Replacement, Align Batter WIth Screw Holes: étape 21, image 1 de 1
    • Align the screw holes on the battery with the screw holes on the computer base.
    Demander à FixBot
  21. Dell Alienware 15 Battery Replacement, Replace Screws: étape 22, image 1 de 1
    • Replace the screws that secure the battery to the computer base.
    Demander à FixBot
  22. Dell Alienware 15 Battery Replacement, Adhere LED Cable: étape 23, image 1 de 1
    • Adhere the front AlienFX LED cable to the battery.
    Demander à FixBot
  23. Dell Alienware 15 Battery Replacement, Route the speaker Cable: étape 24, image 1 de 1
    • Route the speaker cable through the routing guides on the battery.
    Demander à FixBot
3 autres ont terminé cette réparation.
Johnathan Hammond
Membre depuis le 02/28/18
46 149 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
45 membres
2 002 tutoriels rédigés
2 commentaires de tutoriel
This is the Alienware 13 not the 15
Bradley De Souza - Réponse Partager
in what way does it look like 13? dumbass
Rahul S - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 19
30 derniers jours : 85
Total : 16,100
