Aller au contenu principal
Dell Alienware 17 Memory Modules 1 & 2 Replacement
Ce dont vous avez besoin
  1. Dell Alienware 17 Memory Modules 1 & 2 Replacement, turning the computer over: étape 1, image 1 de 1
  2. Dell Alienware 17 Memory Modules 1 & 2 Replacement, removing screws: étape 2, image 1 de 1
    • Remove the screws that secure the base cover to the computer base.
  3. Dell Alienware 17 Memory Modules 1 & 2 Replacement, slide base cover: étape 3, image 1 de 1
    • Slide the base cover toward the front of the computer.
  4. Dell Alienware 17 Memory Modules 1 & 2 Replacement, remove the base cover: étape 4, image 1 de 1
    • Lift the base cover off.
  5. Dell Alienware 17 Memory Modules 1 & 2 Replacement, replacing base cover: étape 5, image 1 de 1
    • Align the tabs on the new base cover with the slots on the computer base
  6. Dell Alienware 17 Memory Modules 1 & 2 Replacement, placing screw: étape 6, image 1 de 1
    • Slide the base cover toward the back of the computer and align the screws holes on the base cover with the screw holes on the computer base.
  7. Dell Alienware 17 Memory Modules 1 & 2 Replacement, secure base cover: étape 7, image 1 de 1
    • Replace the screws that secure the base cover to the computer base.
  8. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Disconnecting the Battery Cable: étape 8, image 1 de 1
  9. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Remove the Screws: étape 9, image 1 de 1
    • Remove the screws that secure the battery to the computer base.
  10. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Releasing the Battery: étape 10, image 1 de 2 Dell Alienware 17 Memory Modules 1 & 2 Replacement, Releasing the Battery: étape 10, image 2 de 2
    • Using the battery cable, lift and release the battery from the tabs on the computer base.
  11. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Opening the Display: étape 11, image 1 de 1
    • Turn the computer over and open the display.
  12. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Grounding the System Board: étape 12, image 1 de 1
    • Press and hold the power button for five seconds to ground the system board.
  13. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Slide the New Battery: étape 13, image 1 de 1
    • Slide the NEW battery under the tabs on the computer base.
  14. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Aligning the Screw Holes: étape 14, image 1 de 1
    • Align the screw holes on the battery with the screw holes on the computer base.
  15. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Replace the Screws: étape 15, image 1 de 1
    • Replace the screws that secure the battery to the computer base.
  16. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Connect the Battery Cable: étape 16, image 1 de 1
    • Connect the battery cable to the system board.
  17. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Remove the Screws: étape 17, image 1 de 2 Dell Alienware 17 Memory Modules 1 & 2 Replacement, Remove the Screws: étape 17, image 2 de 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. . After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
    • CAUTION: Hard drives are extr emely fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  18. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Lifting the Hard-Drive Assembly: étape 18, image 1 de 1
    • Using the pull-tab, lift the hard-drive assembly off the computer base.
  19. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Disconnecting the Interposer: étape 19, image 1 de 1
    • Disconnect the interposer from the hard drive.
  20. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Remove the Screws: étape 20, image 1 de 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  21. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Lifting the Hard-Drive Bracket: étape 21, image 1 de 2 Dell Alienware 17 Memory Modules 1 & 2 Replacement, Lifting the Hard-Drive Bracket: étape 21, image 2 de 2
    • Lift the hard-drive bracket off the hard drive.
  22. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Placing the Hard Drive: étape 22, image 1 de 2 Dell Alienware 17 Memory Modules 1 & 2 Replacement, Placing the Hard Drive: étape 22, image 2 de 2
    • Place the NEW hard drive in the hard-drive bracket.
  23. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Replace the Screws: étape 23, image 1 de 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  24. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Connecting the Interposer: étape 24, image 1 de 1
    • Connect the interposer to the hard drive.
  25. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Align the Screw Holes: étape 25, image 1 de 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  26. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Connecting the Interposer: étape 26, image 1 de 1
  27. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Placing the Hard-Drive Assembly: étape 27, image 1 de 1
    • Place the hard-drive assembly in the hard-drive bay.
  28. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Aligning the Screw Holes: étape 28, image 1 de 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  29. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Replace the Screws: étape 29, image 1 de 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
  30. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Remove the Screws: étape 30, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions After Working Inside Your Computer.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  31. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Lifting the Hard-Drive Assembly: étape 31, image 1 de 2 Dell Alienware 17 Memory Modules 1 & 2 Replacement, Lifting the Hard-Drive Assembly: étape 31, image 2 de 2
    • Using the pull-tab, gently lift the hard-drive assembly.
  32. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Lifting the Latch: étape 32, image 1 de 1
    • Lift the latch and disconnect the hard-drive cable from the system board.
  33. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Lifting the Hard-Drive Assembly: étape 33, image 1 de 1
    • Lift the hard-drive assembly off the computer base.
  34. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Disconnecting the Interposer: étape 34, image 1 de 1
  35. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Remove the Screws: étape 35, image 1 de 1
  36. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Lifting the Hard-Drive Bracket: étape 36, image 1 de 1
  37. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Placing the Hard-Drive: étape 37, image 1 de 2 Dell Alienware 17 Memory Modules 1 & 2 Replacement, Placing the Hard-Drive: étape 37, image 2 de 2
    • Place the NEW hard drive into the hard-drive bracket.
  38. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Align the Screw Holes: étape 38, image 1 de 1
  39. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Replace the Screws: étape 39, image 1 de 1
  40. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Connect the Interposer: étape 40, image 1 de 1
    • Connect the interposer to the hard-drive.
  41. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Placing the Hard-Drive Assembly: étape 41, image 1 de 1
  42. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Aligning  the Screw Holes: étape 42, image 1 de 1
  43. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Replace the Screws: étape 43, image 1 de 1
  44. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Popping up the Memory Module: étape 44, image 1 de 1
    • Using your fingertips, carefully spread apart the securing clips at the sides of the memory-module connector until the memory module pops up.
  45. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Slide and Remove: étape 45, image 1 de 2 Dell Alienware 17 Memory Modules 1 & 2 Replacement, Slide and Remove: étape 45, image 2 de 2
    • Slide and remove the memory module from the memory-module connector.
  46. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Align the Notch: étape 46, image 1 de 2 Dell Alienware 17 Memory Modules 1 & 2 Replacement, Align the Notch: étape 46, image 2 de 2
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  47. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Add new module: étape 47, image 1 de 1
    • Slide the memory module into the connect or at a 45-degree angle, and press the memory module down until it clicks in place.  If you do not hear the click, remove and reinstall the memory module
    • The computer may not boot if the memory module is not installed correctly.
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 1,048
